Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old April 29, 2014, 02:53 PM
sswilson's Avatar
49mm from motherboard PCB to top of heatsink fan.
Just got my 5350 + Asrock AM1H-ITX assembled and am currently installing win8 onto an older sata drive to check it out with. (Installing win8 from early media is still absolutely brutally slow.... ;) ).
Name:  Init Asrock Mobo.jpg
Old April 29, 2014, 04:12 PM
Bond007's Avatar
^^^Nice. I still find it funny seeing the size of MITX in scale to other components. In you pic it looks like that hard drive is a 12"x8" monster. That said I have been considering doing a MITX HTPC for my upstairs TV.
Old April 29, 2014, 04:29 PM
sswilson's Avatar
Yeah, the small scale of mITX gets me every time which is why I railed against the size of the prodigy so much.... :)
Name:  Init Asrock Mobo hotspots.jpg
Not real sure what those three components are, but I do know that they're getting some enzotech sinks on them.... :) (Too hot to touch under moderate load).
Old April 29, 2014, 05:01 PM
Bond007's Avatar
quick google seach tells me they are "surface mount ceramic capacitors"...lol. Doesn't really help with what the are connected to. Nice call on cooling them down. I really wish there were some low budget AM1 motherboards with WIFI.
Old April 29, 2014, 05:16 PM
sswilson's Avatar
Well....... :)
2dBi 2.4GHz Antenna for Wifi Routers and Adapters (4-inch) - Free Shipping - DealExtreme + RP SMA Male to IPEX Adapter Cable - Black + Golden - Free Shipping - DealExtreme + http://www.ncix.com/detail/intel-wir...1-eb-78697.htm will be doing that for me.... the backplate for this particular asrock motherboard already has the cutouts for two antennas.... :)
I suppose it depends on what you consider "low budget", which when compared to the prices on intel mITX boards leaves a lot of room.
Old April 30, 2014, 07:27 AM
Which retailer did you buy your AM1 parts?
Old April 30, 2014, 07:42 AM
sswilson's Avatar
I bought the AM1 parts from NCIX and the antenna gear from DX.
Old April 30, 2014, 08:43 AM
great_big_abyss's Avatar
Nice little computer, that. If all you wanted was a little machine to hook up to your TV to surf the web and watch youtube videos, and you already have NAS, then this would be the rig for you.
  #19 (permalink)
Old April 30, 2014, 08:46 AM
sswilson's Avatar
My usage is essentially as a glorified media player.
  #20 (permalink)
Old April 30, 2014, 09:25 AM
Dr_BenD_over's Avatar
Fallen Folder
Attachment 21719
The ones labeled 2r2 and 3r3?
All's well that's Haswell
The ASUS Eee PC 900 Reviewed Hardware Canucks Mobile Computing 3 June 30, 2008 06:29 PM
OCZ Cryo-Z reviewed! Wankerfx Reviews & Articles from the Web 14 March 13, 2008 06:15 AM
3850 AGP reviewed-yes, AGP Babrbarossa Reviews & Articles from the Web 8 February 19, 2008 02:51 PM
105 PSUs reviewed! Babrbarossa Reviews & Articles from the Web 9 April 30, 2007 05:19 AM
