Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old May 12, 2008, 06:46 AM
b1lk1's Avatar
Well, the only thing I will say in favor of the manufacturers is that they don't officially support the 125W TDP processors on these boards. My lack of research before I bought this combination is really to blame for my problems. I just assumed they would work considering this platform is supposed to be up against the G35 platform.
As for AMD's latest systems, they are fast, but they are not cheap to build a performance system. You theoretically need a $200+ motherboard plus a $200+ CPU to compete with anything Intel has to offer. Since there are no decent $100-200 motherboards that can properly support the best CPU's, you are spending the same as if you bought a faster Intel system. Atleast with Intel you can buy a $99 motherboard that will handle the QX9650.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old May 12, 2008, 07:52 AM
Cheator's Avatar
My M2NPV-VM which was 50 bucks at the time I bought it (like 2 years ago) supports quad core. So does my M2N-E, and my M2A-VM. All of which are 100 bucks or lower.
You're saying that your board doesn't support it?
My Heatware![/SIZE][/FONT] | Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old May 12, 2008, 08:32 AM
b1lk1's Avatar
Partially right. It supports up to the 9550 Phenom which has a 95W TDP IIRC. My board does not support ANY 125W CPU, even the dual cores. That's not to say that my board will not run them since I am currently running my 9850 in it right now. The problem is the terrible cheap design of the PWM area. Pulling the full 125W+ through the CPU power circuits tends to destroy the boards. Anandtech killed 4 of them when they were testing them with a 9850 before they realized what was going on. The real problem is that AMD didn't require the 780G based motherboards to support anything over 95W so the motherboard manufacturers figured they'd save $5-10 per board and use weak CPU power circuitry. Personally, I'd of happily paid $15-20 more for my board for it to have a robust power circuit.
Of course, you can also go with the lame argument that these boards were never meant to use the "high end" AMD processors, but to me that is just a silly excuse being offered for idiotic planning of AMD's latest products.
As for the prices I quoted, I am talking about real AM2+ motherboards that are able to properly run the Phenoms. I could get a regular AM2 board, but that makes little sense since I wanted the latest chipsets.
And think of it this way. AMD boasts the overclockign performance of this chipset, yet even when you OC the 9550 you are sure to pust the TDP close to if not over 125W anyways so even supported CPU's have the ability to overpower and kill these wimpy boards.
Old May 12, 2008, 08:52 AM
Cheator's Avatar
Ah ok. I was wondering since you were running the 9850.
Old March 20, 2009, 07:53 AM
hi, i also have a m2npv-vm!
are you sure it supports quad core phenom?
have you actually tested it?
i really want to upgrade to phenom but I am hesitant to try a quad core in this mobo because none of the phenoms are one the compatibility list from the asus website.
would you mind testing your quad core cpu out on your m2npv-vm?
Old March 20, 2009, 08:30 AM
Read the entire thread... :) It explains this exactly.
Old March 20, 2009, 09:25 AM
Mr. Gruntsworthy's Avatar
Yet one more reason I'm glad I run on Intel machines :P
MAIN RIG:
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
http://mikeseguin.webs.com/
I run Durham 3D Printing, an online 3D Print shop!
Old March 20, 2009, 10:54 AM
Considering this problem was rectified in excess of 6 months ago, I fail to see why this thread was dug out of the graveyard ...
I've been using 780Gs with Phenom IIs with nothing but good results ...
  #19 (permalink)
Old March 20, 2009, 11:04 AM
Chilly's Avatar
That, and the fact this thread is over one year old
Again, this issue has been long gone.
  #20 (permalink)
Old March 20, 2009, 03:07 PM
I'm not to familiar with AMD, so I had no idea... i didn't look at the original thread's posting date :P
MAIN RIG:
MoBo: Asus X99-A
