Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old August 19, 2013, 03:14 PM
Bond007's Avatar
Default AMD Dual Graphics: Better Benchmarks,but Same Experience?
Tomshardware did a review of various AMD dual graphics setups (APU+dedicated).
http://www.tomshardware.com/reviews/...mark,3583.html
Their conclusion is that it improves FRAPS (benchmarking), but not the gameplay experience.
Old August 19, 2013, 03:18 PM
You trust those reviews? That is like saying you trust newegg customer reviews...
Old August 19, 2013, 04:05 PM
Bond007's Avatar
Never said I trust them. I find tomshardware has interesting review ideas, but I take them with a grain (or box) of salt. Just posted it because I haven't seen a review like it before.
Old August 19, 2013, 11:15 PM
Why wouldn't you trust about it?
Is there a test parameter you specifically have an issue with, or have you simply dismissed it out of hand for no reason whatsoever?
Old August 20, 2013, 04:34 AM
when I was shopping around for my htpc upgrade and settled on an A10-6800k, I recall the graphics performance being somewhat comparable to the 7750, according to they're numbers, its way off.
interesting increase in tomb raider with the 7750 in dual graphics, i've been pondering adding a 7750 to mine so I could play tomb raider and a few other more intensive titles
When I saw the difference in performance though, I wondered what speed of ram they were using and had to go back to the 2nd page and check, it's 1866, but why such high latency at CL 13-13-13-34
Old August 20, 2013, 04:46 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Funny how AMD followers began foaming at the mouth in the comments about them not using the 13.8 beta drivers......when EVERY SITE said they wouldn't affect Dual Graphics performance....
Old August 20, 2013, 06:29 AM
The high-end APUs have always been comparable to the 6670 DDR3, even with low-latency 2133 MHz RAM.
The 7750 is *far* more powerful than the A10-6800K's onboard graphics, always has been.
A 7750 would help for sure, but better to use it in single card mode.
Old August 20, 2013, 07:28 AM
Sushi Warrior's Avatar
Dual graphics have been more or less abandoned until XDMA comes into future APU platforms... Dual graphics in the current config is a joke
Old August 20, 2013, 10:28 AM
SKYMTL's Avatar
Agreed. It's not like anyone would want to buy a brand new APU alongside a three year old GPU.
Old August 20, 2013, 05:34 PM
Default This Anyone Did
I bought the AMD - Dual-Graphics package, indeed due to an error on my part in not getting a 6670 with a displayport I ended up with two HD6670's in my system because I decided too late that I wanted a three screen array.
I can say that running in Dual-graphics mode is better than running with just the APU not paired up with a HD6670. I can compare running the APU + HD6670 vs crossfiring the two HD6670's I have in my rig. The results, not a big difference but the two HD6670's were slightly better in benchmarks than the dual-graphic set up but not enough to warrant buying two HD6670's.
Bottom line, a A10 + HD6670 is an improvement over a A10 and can be had for about $70 now.
If I were to redo this all over again I'm not sure I would go the APU route, but I'd have to weigh the cost - benefit. An A10 is $130ish + 70 HD6670 - costs about what a good graphics card will set you back, before you buy your CPU. So it depends, do you want to spend $130 - then the A10 is your best bet, $200, A10 still wins, got $400 to spend, then a better CPU + graphic card is better - it all depends on your budget. The APU is all about price point.
Having said all this I keep looking at the HD7800 series, 2 GB cards - I'm thinking about it. $180 might improve my system performance, but my current rig plays the racing games I have just fine, I run Dirt3, NFS Shift2 and Grid (original) in the higher graphics mode without any issues. Not sure how graphic intensive these games are but they display fine on my three scheens.
________________________________
FKD
Fort Kent, Alberta
2012 - A10 Rig
Dual graphics with Radeon HD 6670 boggy_b1 Video Cards 7 September 29, 2014 05:35 PM
Dual or Quad SLI graphics for a game like battlefield Gameman Advanced Kid Video Cards 12 August 20, 2012 09:51 PM
Sapphire Announces New HD 6970 Graphics Card with Dual-BIOS and Dual-Fan Cooling Sam_Reynolds Press Releases & Tech News 1 November 1, 2011 11:50 AM
ATI Radeon HD 5570 Graphics Brings a Big Visual Experience to Small Form Factor PCs FiXT Press Releases & Tech News 0 February 9, 2010 10:42 AM
GIGABYTE Launches GT240 Series Graphics Cards with Premium Audio Experience FiXT Press Releases & Tech News 0 November 17, 2009 02:09 PM
