Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old March 15, 2007, 09:30 PM
Babrbarossa's Avatar
Super Moderator
Default Antec reveal the P190 and it’s a monster!: Hexus
Hexus will soon be reviewing this case and the p182 -- This one is quite large and has 140mm fans, TWO PSU's, and pre-prepared watercooling holes in the back- and many other pretty neat features- still resembles the p180 though.
"Fresh on the heels of our coverage of the new P182 we bring you its bigger brother. The P190 is the same height as the P182 but slightly wider and much deeper, featuring a re-designed power chamber containing the two power supplies included as standard. These are 650W and 550W watt units. "
More from Hexus
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old March 15, 2007, 11:01 PM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
That's a pretty nice case, but when I saw the two PSU's I was like
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
Old March 15, 2007, 11:09 PM
Super Moderator
It's risky selling the psu's with a higher end case, cuz if they suck or they're not modular, they're going to lose alot of customers- they're aiming for a pretty desciminating crowd. I'd love to try one though.
Old March 15, 2007, 11:25 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 23 - 1,377 points to level up
Antec 900 and Antec 180s are my two most hated cases.
The layout in them is just atrocious for cable management and airflow.
Old March 16, 2007, 07:09 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I don't know why people think that more airflow is better. These cases with massive 220mm side fans always make me laugh.
Old March 16, 2007, 07:27 AM
Patriote's Avatar
Level up: 10% Level up: 10% Level up: 10%
Level: 17 - 721 points to level up
2 Psus that comes with the case ? eh ? What is that ? I want to buy a case not a Psu (Uhh...i mean PSUs) lol Anyways, i didn't liked the design of the P180 so this one isn't for me thats for sure.
• - EVGA 680I A1
• - QX6800ES G0 @ 3.95Ghz
• - SLI BFG 8800GTX @ 626Mhz \ 2000Mhz
• - 4GB G.SKILL F2-6400PHU2-HZ @ 1000Mhz
• - Ultra X3 1000 Watt
• - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX
• - WD RaptorX 150GB \ WD500GB \ WD Caviar 250GB
• - MountainMod U2-UFO Black Powder Coat
• - Dell UltraSharp 24''
Loop #1 : D-Tek FuZion - 2x MCW30 - Cyclone Res - MCP355 w/ Petra's Top - PA120.3 - Tygon
Loop #2 : 2x Ek-FC 8800GTX - Ek 150 Rev.2 - MCP355 w/ Petra's Top - PA120.2 - Tygon
Old March 16, 2007, 08:02 AM
Super Moderator
Cable management is fine in the p180 if you know how to do it- and in that price range, there's nothing wrong with it- it's no lian li or stacker, but it's also half the price.
Old March 16, 2007, 08:53 PM
ScytheNoire's Avatar
I hated the Antec P180 so much, it's the current crap case sitting on my desk. Can't wait to get rid of it, hate it so much. So seeing them reuse that horrible design of the P180 just makes me wonder if they ever looked at all the problems with the P180.
Will be happy when the Silverstone TJ09 arrives from DirectCanada.
Old March 16, 2007, 10:09 PM
Super Moderator
What do you recommend for a case in the 120-150 price range- and what do you own?
Old March 17, 2007, 06:57 PM
Antec cases I've owned are the Sonata, P180, old Soho Tower, and a Thermaltake Tsunami. I love the Sonata, and the Sonata II fixes the only thing I hated about the Sonata, those side holes. But then the Sonata I use in the bedroom, because it's quiet, it's not a good high-end gaming case.
I think that the Antec Nine-Hundred seems to be a good value case, for the price, and would do great as a gaming case.
But really for high-end cases, you are looking at Silverstone, Lian-Li, and CoolerMaster Stacker cases. Thermaltake makes some good cases, especially for water cooling, and I'd also recommend the new Gigabyte case, which has a lot of good features.
But the Antec P180, and the P190 from the looks of it, just suck. The P180 has some good features, but the front door sucks, the side panels don't fit the best, and it's rather cramped inside for it's size. Not to mention the stupid partition between the PSU and the mobo area. But it's just a really cramped case, not enough room. I doubt an 8800 GTX would fit properly inside.
Project: P190 MpG Worklog 44 May 7, 2008 09:47 PM
The Silent Monster Dark Worklog 3 January 9, 2008 01:40 PM
HEXUS has Crysis—DX10 hands-on Supergrover Press Releases & Tech News 9 August 27, 2007 12:41 PM
25 CPU Cooler roundup for LGA 775: HEXUS Babrbarossa Reviews & Articles from the Web 6 June 7, 2007 09:01 AM
Antec P190: I have fallen and can't get up... 3.0charlie Cases 18 May 28, 2007 06:12 PM
