p180 is just atrocious for cable management even IF you are good. You gotta buy a 8" extension cable just to route cables properly and even then the bottom end is junk. You have to remove the upper tray plus other parts for good air flow if running any good setup of a system. Personally the only Antec case I like is the Titan 550 and my favorite case is the Coolermaster Stacker CM. The p150 and Solo are the same identical cases just one is black and one is white. The Antec 900 is a piece of junk as well because who on earth came up with that lousy hard drive caddy system? Unplug your fans, undo 8 screws, pull tray out carefully. Blah. Centurion CAC-05 for a generic case. |
| Quote:
I'm not saying we need a tornado going on, but what about my highly overclocked PC with overvolted memory and chipsets? You're telling my a good CPU fan and exhaust fan is going to cool them down as well? And what about my hard drives? I realize that they don't need active cooling, but no airflow around them is not good. I will never in a million years believe that your suggested setup is better than something simple like mine. Unless of course you run stock.........
__________________ ASUS P5Q Pro w/C2D E7200 Mushkin Redline PC2-8000 2X2GB Visiontek HD 4870 512MB w/Dell 2709W BFG 680W LS ASUS Xonar DX2 w/Logitech Z680's Swiftech MCW655/Thermochill 120.2/Apogee GT/DD 4870 Coolermaster HAF 932/Vista 64 Ultimate |
Oh yeah, I forgot to mention my - water cooled - CPU. THere is no CPU fan. Your airflow model may work for a bone stock air cooled PC, but you can't use it as the model for all PC's.
| Hard drives don't need air, its been also proven that excess heat doesn't harm hard drives.
| What about my chipsets, ram, moffsets, vregs, etc.. ?
Airflow is more about position than fan speed and size. the larger the fan, the more air it can move at a lower speed. for an 80mm fan to move as much air as a 120mm fan, it has to be rotating faster, thus, more noise. location plays a big role in that top ventilation helps a lot in removing hot air. you want your intakes on the bottom front and outakes on the top back. it's not rocket science. :p but i'd prefer to use more slower quieter fans than a few faster running fans. with the Silverstone TJ09 i will be using up all the fan spots, but the fans will be running at 1200RPM, so it will be very quiet. using top-end fans like the Noctua's ensures maximum airflow for the minimum noise level. |
I happen to like a bit of noise out of my computer... (let's me know it's running... :) ). Computers with C&Q running drive me nuts.... the only thing letting me know that it's up and running is the light......
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
People are so negative- I don't know why the best anyone can do is **** all over everything without offering anything in return- it's so easy to shoot stuff down-
__________________ Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Project: P190 | MpG | Worklog | 44 | May 7, 2008 09:47 PM |
| The Silent Monster | Dark | Worklog | 3 | January 9, 2008 01:40 PM |
| HEXUS has Crysis—DX10 hands-on | Supergrover | Press Releases & Tech News | 9 | August 27, 2007 12:41 PM |
| 25 CPU Cooler roundup for LGA 775: HEXUS | Babrbarossa | Reviews & Articles from the Web | 6 | June 7, 2007 09:01 AM |
| Antec P190: I have fallen and can't get up... | 3.0charlie | Cases | 18 | May 28, 2007 06:12 PM |
