October 25, 2012, 08:50 PM
 | MVP | | Join Date: Nov 2010
EK Introduces its First AMD C32/G34 Water Block [TechPowerUP] Quote:
EK Water Blocks, Ljubljana based premium performance PC water cooling gear manufacturer, is excited to introduce it's first AMD C32/G34 socket water block thus introducing high performance water cooling to the server and workstation market. EK-Supremacy AMD C32/G34 is the ultimate water block for server- & workstation type motherboards featuring one or more AMD C32- or G34 sockets. Moreover this product also supports AMD's older Socket F. Included PreciseMount mechanism offers error-preventing, tool-less installation - the result is a perfect installation which results in optimal performance every time.
EK-Supremacy is a result of round clock development, years of experience and rigorous testing. As a new EK flagship this product again combines top hydraulic and thermal performance.
EK-Supremacy is a successor of the legendary EK-Supreme HF water block launched in 2010. It's main improvements are:
- better hydraulic performance: due to improved design up to 20% higher flow compared to EK-Supreme HF
- better cooling performance: up to 2°C lower CPU temperatures compared to EK-Supreme HF
The EK-Supremacy cooling engine uses similar, yet refined as per needs of modern microprocessors, fin design as its ancestor. The cooling liquid accelerates through jet plate's nozzle and turbulently continues its path through numerous very thin channels which provide extreme cooling surface area. Specifically designed and carefully machined copper base (sometimes referred to as 'cold plate') is made from purest copper available on the market and is further polished to absolute mirror finish. This alone greatly improves the cooling performance of EK-Supremacy. CPU socket compatibility:
- AMD Sockets: F, C32, G34 Enclosed in the box:
- EK-Supremacy AMD C32/G34 series water block
- EK-Supremacy PreciseMount AMD C32/G34 mounting mechanism
- TIM / thermal grease: Gelid GC-Extreme (EKWB 1.6g)
The EK-Supremacy AMD C32/G34 series water blocks are readily available for purchase through EK Webshop and our Partner Reseller Network.
| Source: EK Introduces its First AMD C32/G34 Water Block | techPowerUp |
