Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old May 14, 2012, 03:30 PM
Default Cheap thermal paste inside Ivy Bridge
Saw this article on Engadget . Basically, it alleges Intel used crappy thermal paste between the CPU die and the external heatspreader which cause the higher than expected temps.
Intel caught out using cheap thermal paste in Ivy Bridge? -- Engadget
Old May 14, 2012, 04:11 PM
GT7R's Avatar
Yeah, read that yesterday. What a fail.
Old May 14, 2012, 04:36 PM
I've been following that since overclock.net threw it up, although there are conflicting stories as to whether replacing the paste or delidding the CPU has an impact. I won't post links because all the sites seem to be copy-pasting the same two stories (one for delid, the other against) both have very questionable "testing methods" probably to increase traffic more than to add to our knowledge of IVB processors.
Heck, we still don't have a good set of results from Ivy + high-end cooling beyond Anandtech's test with the Intel water cooler.
What I'd like to know is if a high mounting pressure cooler Prolimatech Super Mega CPU Cooler Review would have an effect, because that would certainly be less risky than taking off the IHS and trying to find a way to keep the CPU from sliding around in the socket...
Old May 14, 2012, 05:39 PM
sswilson's Avatar
Heh... I'm all for a return to enthusiasts removing the IHS.... it's high time we re-injected a little bit of the fear factor into high end overclocking.... :)
Old May 15, 2012, 05:00 AM
Jebusman's Avatar
It's funny reading some of the comments on that Engadget article, you can tell how clueless some of them are, screaming
"WHY IS THIS AN ISSUE WHO USES THE STOCK THERMAL PASTE ANYWAY BUNCH OF RETARDS LEARN TO COMPUTER"
without reading what the article is about.
Also, I'm assuming removing the IHS on this processor wouldn't be nearly as dangerous as normal, since it's just TIM underneath, instead of fluxless solder. Still risky, but not as risky as it could be.
Old May 15, 2012, 12:52 PM
I wonder how did they remove the headspreader with Sandy Bridge. I thought fluxless solder would really stick the die and headspreader together. To risk obvious voiding the warranty to OC it just a tad more seem silly. Wouldn't a decent water loop or integrated single unit water cooling do the trick?
Old May 15, 2012, 01:35 PM
dandelioneater's Avatar
I don't think that much of a temperature improvement could be achieved by opening up the chip, but Kudos to those who are willing to push the limits and try things that most wouldn't.
Old May 16, 2012, 04:36 AM
Jebusman's Avatar
Blowtorch. You pass it over the IHS for an instance of a second multiple times, until you just reach the melting point of the solder. Then you take off the IHS, and PRAY the die doesn't come with it. Clean off the excess solder, and ta-da, naked SB.
You've got about a 1 in 4 to 1 in 1000000 chance, depending on who you ask, of doing it successfully.
And OCing was always about voiding the warranty just to push it a little bit more. It's just in the last few years it's gotten easier and easier, and a lot more commonplace.
Old May 17, 2012, 10:56 AM
b1lk1's Avatar
This story sounds like it came from AMD's PR team.
As for overclocking, it is a joke how easy it is yet so many refuse to even learn the basics before posting the obligatory "how do I OC my PC" thread.
MY HEATWARE
which thermal paste? techman95 Air Cooling 34 March 27, 2012 10:55 PM
Thermal Paste The Quicken CPU's and Motherboards 10 December 17, 2011 07:50 PM
Thermal Paste killerjay_47 Air Cooling 9 March 15, 2010 02:53 PM
Thermal Paste? Luckk Air Cooling 16 November 24, 2009 07:57 PM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 05:43 PM
