Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old March 27, 2008, 05:12 PM
vdf22's Avatar
"If you’ve set a strict budget of $500 or under the GeForce 9800 GTX is going to be the graphics card of choice. If you find yourself though being tempted to spend more, the Radeon HD 3870 X2 is probably going to quickly become a real possibility with all the numbers considered."
Huh? The 3870X2 is under $500.
Old March 27, 2008, 05:17 PM
magictorch's Avatar
Why is it called a 9800GTX??Its a great card but isn't it just an over-clocked 8800GTS 512mb with better memory chips.
Old March 27, 2008, 05:24 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
WTFWTFWTFWTFWTF.
Where the HECK did those numbers come from? Maybe those benches are all at VERY low IQ settings...
Old March 27, 2008, 05:48 PM
Cptn Vortex's Avatar
Hahaha, well put.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 27, 2008, 06:03 PM
SKYMTL's Avatar
All right....getting my head on proper...it seems that they are benching with a quad @ 3Ghz and there is no mention of quality settings used for the games. So, it may be that the GX2 and X2 are being bottlenecked.
Old March 27, 2008, 06:44 PM
Prof. Dr. Silver's Avatar
Really? Bottlenecked? I find that a bit strange....besides their OC'ed CPU they're also using extreem low latency memory....that helps out just a little. Prob a fresh clean install of the OS. As far as I know you have a similar setup right? Is there such a huge difference? And is it positive or negative, the difference I mean....
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
