Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old January 17, 2012, 09:01 AM
Default Intel SNB-E i7-3820 review
Basically, it's 5% better than 2600K but at a lower price. However, once you factor in motherboard, CPU cooler and 4 sticks of RAM, it cost more.
Intel Core i7-3820 Processor Review - Quad-Core Sandy Bridge-E under $300 | PC Perspective
Old January 17, 2012, 09:26 AM
Eldonko's Avatar
Hardware Canucks Reviewer
5% in single card 3d. What about SLI tests? Half the point of the 40 PCI-E lane SB-E platform is multi-GPU. When this chip goes retail I think it will be tough to recommend a 2600K over a 3820 for someone building a new system.
Old January 17, 2012, 11:48 AM
Agreed for the most part, but it will depend how motherboard prices end up. If they come down in price it will likely be a hands down choice, but if they don't then there will be cases/budgets that would be better off with 2600.
As for the ram there was a review on another site (can't remember off hand from where) that tested with 2/3/4 channel configs on a SB-E CPU and for the most part there was no difference. Meaning You could start with dual channel and upgrade as required (or if required).
Edit: that said I think this will be the way to go for someone that wants more than a 2500k pending final pricing.
EDIT 2: Here is the review that contains the 2/3/4 memory channel tests.
DDR3 SDRAM for LGA 2011: Which Memory Is Best?. Page 3 - X-bit labs
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old April 10, 2012, 08:48 AM
elmorejohn46's Avatar
Does anyone else have a i7-3820 and could tell me if getting conductive paste in that hole would cause any problems.
Old April 13, 2012, 09:59 AM
monkey_mo's Avatar
Omg i was wondering about that too, i thought it was such a noob question, were p4 chips the last chip to have a hole on the top part of the cpu
Old April 13, 2012, 11:21 AM
No. There are no issues getting paste in the hole, the last thing I saw with a hole in the heat spreader was a gtx480.
And you do not want to be using an electrically conductive paste any way.
Edit: Proof : Nerds Guide To Baking Your Own GTX480 Keyring! - YouTube
That would make a sick key chain.
Old April 15, 2012, 03:54 AM
That is the reason I bought the i7-3820 is because I have three GTX-470 and don't want to upgrade yet since two of them are fast enough .I run them at 725/1750 so I can keep the voltage at default,but they will run at 830/1900 but then I have to up the voltage and speed up the fan to loud.But I check with intel and they said it would not hurt if paste got in it ,but I will be useing Artic Silver ceramique to be on the safe side.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Intel to Release Intel Core i7-3820 on February 13 Sam_Reynolds Press Releases & Tech News 1 January 7, 2012 03:25 PM
Intel Core i3-540 Review Comment Thread SKYMTL CPU's and Motherboards 17 January 11, 2011 11:24 AM
Intel Core i7 Cooler Review [ Hard OCP ] gingerbee Reviews & Articles from the Web 3 October 18, 2009 06:46 AM
Intel Lynnfield i5-750 & i7-870 Review Comment Thread MAC CPU's and Motherboards 44 September 8, 2009 08:10 PM
