Originally Posted by ilya If you look carefully at the design specs, this isn't that great of an idea. At most it might replace stock heatsinks.
1. The fan motor is very close to the thermal load.
2. The current design requires 10W to operate, the future revisions will feature a more heavy duty higher consumption motor, driving up consumption.
3. There is 3 nanometres of air conducting heat from the base to the fin array, it seems there aren't any good material candidates to replace air at this time.
4. Performance will diminish significantly when higher RPM's are required, due to friction.
All this design really does is it eliminates the dead air layer that insulates traditional downdraft heatsinks, which only increases the efficiency of fin to air heat transfer. Most enthusiast/high performance/server heatsinks aren't affected by this issue. |
Ahhh perhaps but being an early stage prototype it is still a long way from being marketable. There are a lot of engineering fixes that need to be applied to make it practical but I can see potential.
ST
