<~----> 6950 review inaccurate? - Hardware Canucks
Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old April 1, 2011, 10:12 PM
Trial Member
Default 6950 review inaccurate?
Hello,
As you guys may know, a while back ago in January 2011, Hardware Canucks did a review on the 6950 1gb. But for some reason, the review greatly differs from another respected site
Specifically, the overclocking potential, the power consumption and temperatures on the 6950 1gb are much better in the review posted by techgage. I can understand why the overclocking can differ from card to card but I don't understand how the heat and power usage could also be so different. I heard that the 6950 1gb cards had revised PCB's a while back, so could this be the reason why the 6950 1gigs did so differently? If that is the case then the original review would be inaccurate and I think that a re review should be done. Especially now that the older PCB's are already depleted and no longer being sold. What do you guys think?
Old April 2, 2011, 06:57 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Every review is naturally different in the three points you listed.
First of all, overclocking potential can vary wildly from sample to sample while power consumption really depends on the system used along with the application running to load the GPU. Temperatures will be affected by ambient conditions so you can't necessarily draw parallels between two different results there either.
You may have "heard" that 1GB cards received revised PCBs but that isn't the case. There are still plenty of products out there with the reference PCB but some AiBs have released non reference designs with custom heatsinks. Naturally, those will give completely different results.
In short, we won't be re-reviewing it since our results are still accurate.
Old April 2, 2011, 07:43 AM
what can actually change is performance in some games with different drivers.
the same exact card may overclock to a certain degree in my pc, but not as good in yours.
different hardware, different conditions.
if youre looking to flash your 1gb 6950, grab the unlocked bios and go for it, but only if you have the dual bios/switch
pcb thingie. else,be good and dont toch it :)
Hd 6950 ? Hexofire Video Cards 5 March 29, 2011 02:43 AM
AMD Radeon HD 6950 1GB Review Comment Thread SKYMTL Video Cards 17 January 31, 2011 04:14 PM
AMD Radeon HD 6970 and HD 6950 Review Comment Thread SKYMTL Video Cards 120 January 7, 2011 05:13 PM
