Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old March 15, 2011, 04:27 PM
techman95's Avatar
the only way i can see it being compatible with the formula is it already having extra pins cause isnt the am3+ supposed to have like 50 extra pins or something
Old March 16, 2011, 05:44 AM
No, I believe it has 1 more, so that old CPUs will still fit in the socket.
Old March 16, 2011, 05:48 AM
Arinoth's Avatar
Future proofing isn't always a good thing with hardware as you have to still support and have a similar architecture to legacy ones, making the newer architecture not as potentially effective or powerful due to this.
Old March 16, 2011, 06:09 AM
CMetaphor's Avatar
Quadfather
I think thats its fine actually. The processor will work in the "legacy" motherboard, just without full features, but still perform better than the previous processor. Then, when you do eventually upgrade your motherboard, it gets even better
Old March 16, 2011, 06:22 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
If you notice, not all past boards WILL support the new chip. Take the GB UD5 890 for example. ONLY the latest revision 3.1 boards will support it. Earlier versions will not. This leads me to beleive that the "universal" socket is a late addition, and its a bit misleading to say "all" of a given motherboard will work. I'd be awfully damn careful BEFORE assuming it will work in you existing mobo. CHECK the mfg'er site to see which revision IS supported, check your mobo to see what revision you HAVE and then and only then assume it will work (or wont).
GIGABYTE - Motherboard - Socket AM3 - GA-890FXA-UD5 (rev. 3.1)
vs
GIGABYTE - Motherboard - Socket AM3 - GA-890FXA-UD5 (rev. 3.0)
Old March 16, 2011, 08:13 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
The issue is the ROM size. 16MB is needed for Bulldozer and not many boards have that.
In addition, NOT ALL Bulldozer-class CPUs will be compatible with these boards. Only certain ones will.
Old March 16, 2011, 08:48 AM
Grampa's Avatar
vs
Yes, this is what I was alluding to in my earlier posting.
Thanks AkG for the links, and clarifying.
Old March 16, 2011, 09:17 AM
techman95's Avatar
wasn't there a page some one posted a while back saying M.S.I would support am3+ with existing boards and they would only need a new bios flash. maybe its gonna be a way for the companies to keep cost down, just add a slightly different socket to its already existing 800 series boards.
  #19 (permalink)
Old March 16, 2011, 09:25 AM
CMetaphor's Avatar
Quadfather
Perhaps you'd like to clarify just Why they need 16Mb Sky? Or is that kind of info NDA-centric? lol...
  #20 (permalink)
Old March 16, 2011, 09:30 AM
vs
If you look at the pictures of the MOB you linked to the 3.0 has AM3 stamped on the board and the 3.1 has AM3+ stamped on it. Also, the 3.1 looks like its has one or two pin holes that are open on the top right of the socket picture that are closed over on the 3.0.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
[WTB] [WTB] 775 or am2+/am3 ddr2 mobo that support latest cpus _dangtx_ Buy/Sell & Trade 13 July 24, 2010 07:25 PM
Asus Prepping Support for Core-i9 CPUs FiXT Press Releases & Tech News 24 December 17, 2009 05:31 AM
Does 790X (not GX) mother boards support Dragon Platform? Pokeguylow CPU's and Motherboards 9 May 8, 2009 05:26 AM
AMD AM3 DDR3 Boards on the way!! SKYMTL CPU's and Motherboards 6 January 23, 2009 12:21 AM
ASUS Claims Leadership in Support for Next Gen AMD CPUs Hardware Canucks Press Releases & Tech News 0 June 2, 2008 05:17 PM
