Cooler Master V6GT CPU Cooler [quote]Cooler Master said that the V6GT would outperform the V8 in their reviewers guide,and it did just that. http://www.legitreviews.com/images/r...r_v6gt_008.jpg Cooler Master V6GT CPU Cooler Review - Final Thoughts and Conclusion - Legit Reviews Legit Bottom Line: Cooler Master’s V6GT is a solid performing cooler, albeit a little noisy, but you’re not going to hear it over your GeForce GTX 480 cranking away at full load. |
Yes it is a beast. Yes it will beat the V8....but then again damn near any good cooler will. Thats all I personally am saying for now on this wonderful cooler. ;) |
looks like well have a review too :) just like the cm 430 when are they going to make smalelr coolers and still be able to cool a ton, without weighing one? :) |
Heh.... I'm a little bit concerned that the best they could come up with for noise levels was that the 480 is louder...... ;) |
lol. but seriously. how many 'scientists' in white lab coats does it take to design a winning design that actually doesn't weigh 2 pounds or more? |
Or we invent a Material with better thermal transfer properties. Silver would be a good start but it has its own issues, and copper is very heavy for a whole heatsink. It just ain't gonna happen Dan, not while we also complain that a cooler costs too much as well. ST |
I'm not a thermal dynamics kinda guy, but the way I look at it is that you need a difference in the temperature potential between the heatsink and the IHS for any cooling to happen. Even if we had a practical one-way barrier between the two, once the heatsink reaches the same temp as the IHS, no further heat transfer will happen. Now if we could figure out a way to convert that heat energy (on the heatsink) to actual work we'd have something to look at...... maybe we need a micro-organism heat/fuelcell that feeds off heat and produces electicity which can then be used to power fans to provide better cooling...... Sorry... kinda rambling here...... must be a slow news day...... ;) |
The Fans (well actually the Air the Fans Move) are what wick the heat away from the Sink. Having a better material will help improve the amount and speed at which it is transfered. If you look at the thermal properties of Metals you will see that Silver is Above Pure copper by a good fraction. The more efficent the material the higher transfer possible. Though we are limited to what the Thermal Transfer in Air is as well, which is why higher speed fans do better, because it becomes a Volume issue at that point too. Mind you my mind isn't sharp today so I might have something wrong here lol. I do read a lot on Thermal Properties and Dynamics, but thats in my spare time hahah. So I might be a bit off. ST |
| All times are GMT -7. The time now is 08:54 AM. |
