Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old May 10, 2010, 06:45 AM
Mark's Avatar
You will not get much gain from such a setup vs a standard watercooling setup with a proper rad. Pushing your CPU from.. say ambient room temp to 20C more will give only give you a little bit of loss compared to his 0C ambient temp and primed to 22C. Then there are a slew of disadvantages including condensation issues, noise and the amount of increased load on your home electric bill!. The best approach would be a standard pump and a good rad...you don't need a reservoir...or go UBER and use N2. I sold my Prometia based on the lack of plausible cooling of my 4 core processor.
CHEERS
Old May 10, 2010, 06:53 AM
gingerbee's Avatar
thanks that's the answer i thought it was going to be. i have only used air or water never peltier plates is that right?
Tags
amd , linus , new build
$1500 BEAST:Need HELP!!! Lavitz New Builds 11 October 28, 2009 08:15 AM
Hopefully a beast. majestikk New Builds 9 August 11, 2009 07:23 AM
Tearing apart a beast Lpfan4ever Case Mods, Worklog & Gallery 0 May 9, 2009 12:28 AM
The Beast (not really) in all its glory. Soultribunal Case Mods, Worklog & Gallery 11 December 11, 2008 07:32 PM
The Beast is Toast Shredder CPU's and Motherboards 5 October 5, 2007 10:53 AM
