Originally Posted by sswilson (1T)?????
I haven't had a chance to run through the original review (pretty busy working on a review of my own... :) ), but did you get a chance to compare bandwidth between (1T), and (2T)? |
no comparison in the review but ask and ye shall receive:
rightmark 8-7-6-20 1T DDR3-2000 / min=6555.95 max=18093.51 avg=8936.81 rightmark 8-7-6-20 2T DDR3-2000 / min=6459.37 max=18052.63 avg=8818.52
Everest 4.10 - 3 consecutive runs each
Code:
Timing Read Write Copy Latency
1T 11639 9123 9877 59.2
1T 11605 9124 9858 59.2
1T 11611 9120 9843 59.3
2T 11577 9125 9837 59.8
2T 11555 9094 9790 59.8
2T 11541 9118 9791 59.8
ScienceMark 2.0 - Memory Bench
Code:
Timing Bandwidth
1T 9301.62
1T 9324.22
1T 9300.87
2T 9187.33
2T 9135.21
2T 9139.58
SuperPi 32M - 1T= 13m 29.844 / 2T= 13m 33.781 (all secondaries exactly the same and method for running was identical from a clean reboot)
click for full size including memset...
As you can see, there isn't a significant difference between the two but all the bandwidth measurements and SPi indicate an advantage to 1T. so there is definitely a change between 1T and 2T but is itsn't as large as say on AMD with the integrated memory controller.
Originally Posted by enaberif holy crap 3.5ghz on a e6600 stable? I can only achieve 3.4 :( |
sorry for your misfortune...i'm 3.7GHz Orthos Blend priority 9 stable for hours on this badboy with a Thermalright Ultra-120, but more importantly, there is no wall until 560FSB on air.
Originally Posted by SKYMTL On the other hand...maybe someone can explain to me what the point is of measuring ANY voltage on a motherboard with a DMM. I'd love to hear an answer because I can think of at least 3 reasons why it would give a very inaccurate reading. |
please do explain, measuring voltages directly from the motherboard is more than an accepted practice in overclocking circles and has been for more years than i know by electrical engineers in the OC scene.
how else are you suppose to measure the voltage going to the component you are adjusting with the variable resistor? and why is it so in-accurate?
i admit, your knowledge from an electrical point of view is greater than mine but my knowledge of hardware and how it relates to overclocking is much better and i have been reading from motherboards since the day i started with remarkable consistency.
interested to hear your thoughts on this subject Michael.
