Originally Posted by enaberif Just because a car has a speedometer that goes to 220 I suppose we should right? I mean why waste all that speed?
Its something that is not necessary. |
What? That's a terrible metaphor. Maybe it would apply if we were discussing processor overclocking but in this case it's more like having to drive people between two destinations and using a minivan or a bus. We're talking capacity, not speed.
Originally Posted by LaughingCrow Peter Bright at Ars Technica tried the monitoring programs and says this:
“So it was little surprise that, upon checking my reported stats on XPnet, I found that I too was in the "alarming" position of having virtually no free memory. A quick glance at Task Manager revealed the truth. Though my "free" memory is indeed negligible, this is because so much is used by cache. The important number is not "free," but "available." The "available" memory includes both memory that is free, and memory that can be trivially made available, and this figure is far more representative of the true amount of memory available to applications. The vast majority of cached memory can be freed up near-instantly, since it is used up merely by cached data from disk.” Behind the Windows 7 memory usage scaremongering |
Ah, thank you.
Somebody else brought up that they've been running more programs since they started running W7. I have too. I think most people will given the newer features like hovering over tasks to make everything but that window transparent, the much more effective taskbar design, and of course being able to split a screen equally between two windows just by click + drag. There are so many variables and so few controls in XPnet's "study" that it's, quite frankly, an insult to statistical analysis; a field I don't have a lot of love for in the first place.
