Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old January 25, 2007, 07:48 AM
Supergrover's Avatar
Default TechSpot stages Core 2 E4300 vs. E6300 overclocking battle
"There appears to be quite a demand for the E4300 at the moment and we are not quite sure why. The processor is nowhere near $130, and at best users will pay $10 less for the E4300 when compared to the E6300. The E6300 is clocked 60MHz higher and runs on a 1066MHz FSB, it would seem the $10 saving is simply not worth it. However, the E4300 is (or should be) all about overclocking so we decided to give it a go, pairing it against our 3.50GHz E6300, which I should add overclocked easily using it along our new Gigabyte 965P-DS3P (rev 2.0) motherboard.
Although the 3.20GHz mark can be reached much easily and requiring no additional cooling, 3.50GHz is possible with an upgraded air-cooler. Therefore, it was decided that rather than using the Intel stock cooler, we would overclock the E4300 using the same after market air-cooler. The heatsink of choice was the Thermalright Ultra-120 paired with a 120mm Thermaltake case fan. Read on to find more."
More @ TechSpot
R.I.P.
Old January 25, 2007, 09:41 AM
yah i'm stilll holding off to see what happens with the 4300
Old January 25, 2007, 11:37 AM
Oh but there going to be $100cdn.
Sarcasm it just cant be relaid over the net.;)
R.I.P.
Old January 25, 2007, 12:14 PM
Deathspawner's Avatar
I thought the E6300 was a superb "budget" chip... looks like the E4300 tops it. Intel is on a serious roll.
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
Old January 25, 2007, 12:37 PM
I know it's scary but I think my next rig is going to be a Intel, the last intel I owned was a 550.
R.I.P.
Old January 25, 2007, 02:49 PM
Haha, yeah. I went from a Socket 7 then straight to AMD. Core 2 Duo is just too good to avoid though. You'd be foolish to go AMD now, unless you want the low-end models, which happen to be superb overclockers.
Compact Watercooled Gaming Rig! (planning stages) Cptn Vortex Case Mods, Worklog & Gallery 9 January 11, 2008 09:57 PM
E6300 + 965p Ds3 h0nam Overclocking, Tweaking and Benchmarking 8 August 13, 2007 08:30 AM
Comment thread for "Core 2 Duo e4300 vs. e6400: Performance on Air and Water Cooling Babrbarossa CPU's and Motherboards 12 August 7, 2007 09:12 AM
Core 2 Duo Batch Number threads for overclocking Babrbarossa CPU's and Motherboards 42 June 4, 2007 08:37 PM
