Originally Posted by MpG That said, I find their "green-lighting" of using a x4 slot on a P55 board to be a little stupid - it's going to have to deal with a DMI link bottleneck, and compete with everything else using the PCH as well. Two cards at x8, sure. Three? Buy a damn X58 board, cheapskate. |
Although the x4 wont bottleneck the GPU much, if you can afford three 5870s, you could have easily enough purchased a X58 system for only a small amount more money. So while the x4 may be "fine" to use on P55, its much easier just to be smart about it and buy into X58. Some company could perhaps split the PCIe into x8/x4/x4 instead of x8/x8/x4 using the extra x4, the board will likely scale better with three GPUs instead of only two. As you said, the x4 is enough, but throw in the other things using the PCH and you will likely start getting a more significant drop in performance.
