-   Reviews & Articles from the Web (http://www.hardwarecanucks.com/forum/reviews-articles-web/)
-   -   10 things to consider about digital cameras (http://www.hardwarecanucks.com/forum/reviews-articles-web/1664-10-things-consider-about-digital-cameras.html)
Babrbarossa June 18, 2007 06:42 AM
Digital Camera HQ made a list of 10 things they feel are important when buying and using a digital camera- some are pretty common sense, but it's fairly helpful over all.
There is a popular misconception that more megapixels lead to better pictures. This is not the case.
Sure, higher resolution gives you the ability to crop more aggressively or print large pictures, but only a fraction of digital photographers will benefit from this ability. If you're a casual shooter who won't be printing pictures larger than 8x10" or doing extensive computer editing, then a camera with 3- or 4-megapixel resolution will be sufficient.
More advanced photographers will likely appreciate the flexibility of higher resolution, but a 5+ megapixel camera is by no means necessary to create stunning pictures. Choose a camera you can understand and afford, and don't be fooled by glitzy high-resolution specs.
Patriote June 18, 2007 12:08 PM
Babr...You rock! Thanks for that article! Real useful since im looking for a digital camera.
Babrbarossa June 18, 2007 12:12 PM
here's some recommendations for you :
Best New Cameras of '07!
Best Pocket Cameras
Best All-Around Cameras
Top SLR Cameras
