| These new chipsets seem to be pretty fast with their faster memory speeds contributing significantly- the interesting thing about these chipsets with the DDR3 seems to be that loose timings are well worth the higher clockspeeds. Rob got this and the p5k3 to 475-480 FSB which isn't too shabby- I bet future bioses will bring it over 500. Compared to the P5K3, the P5K retails for around $30 - $40 less, but essentially offers the exact same performance. The P5K3 only has an obvious advantage because the stock memory was running at a higher frequency. That said, $225 is well worth the cost of this board if you are looking for one that's feature-rich. There is a non-deluxe version of the board available for $150 on average, but it lacks WiFi, a PCI-E 1x slot, two S-ATA ports among other things. I am also unsure whether you could expect the same performance as seen in this review. In the end, I'd easily opt for the Deluxe version because it's complete. Here's a pic with the P5K left and the P5K3 on the right- the only difference is in the heatpipes? More from TechGage
__________________ Gaming Rig: evga 680i rev. A1 // Q6600 @ 3.51 // evga 260GTX 216SC// 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Asus M3A32-MVP Deluxe/WiFi-AP | chibi_man | CPU's and Motherboards | 20 | February 4, 2008 04:15 PM |
| Asus P5B-Deluxe Wifi/AP motherboard + MOSFET waterblocks | Apollo4g | Buy/Sell & Trade | 3 | January 12, 2008 01:50 PM |
| Sata Problem on Asus P5K-Deluxe WIFI/AP | neurobashing | CPU's and Motherboards | 1 | August 14, 2007 08:50 PM |
| ASUS P5K3 Deluxe WiFi-AP review by TechGage | Babrbarossa | Reviews & Articles from the Web | 3 | June 4, 2007 03:17 PM |
| Asus P5K3 Deluxe WiFi AP with DDR3 review by Bit_Tech | Babrbarossa | Reviews & Articles from the Web | 4 | May 26, 2007 03:35 PM |
