| I've been wondering what the deal with this "Sytem Elite" memory is. Big Bruin manages to toghten the timings down to 4-4-4-13 which is better than many OCZ Gold kits will do, but there is also the OCZ Vista Edition kits that are most likely the same thing, and are cheaper. The performance of the OCZ Technology PC2-6400 System Elite 2GB Dual Channel DDR2 was respectable in all tests conducted. It performed on par with other kits with similar specifications, and by tightening the timings from the published values of 5-5-5-15 to 4-4-4-13, the results were even better. The System Elite series is something slightly different from OCZ Technology's typical fare, as it isn't really an enthusiast grade of DDR2 memory. It is intended for those who want the reliability and compatibility they know they will get from the OCZ brand name, minus some of the performance features and overclockability they might pay extra for. That said, this kit still boasts some enthusiast style features, such as the flashy copper heatspreader, EVP coverage up to 2.0V, a lifetime warranty, and the ability to run at the enhanced timings of 4-4-4-13. Just don't count on this kit carrying you to a high overclock, as that did prove to be one of this kit's weaknesses. Pros: » Rated at 5-5-5-15 timings, capable of more aggressive 4-4-4-13 » Performed well when compared to other DDR2-6400 » Lifetime warranty » OCZ's EVP coverage for use up to 2.0V » Basic memory with some enthusiast features and styling Cons: » Not for overclocking » Relatively expensive More from Big Bruin
__________________ Gaming Rig: evga 680i rev. A1 // Q6600 @ 3.51 // evga 260GTX 216SC// 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| x-fi elite pro and vista 32bit, anyone using? | Ukonjack | Audio | 2 | January 11, 2008 10:40 AM |
| Anyone using an X-FI Elite Pro-opinions | Ukonjack | Audio | 1 | November 28, 2007 07:02 PM |
| Which Memory? | BALISTX | RAM | 11 | April 3, 2007 11:52 PM |
| ECS PN2-SLI2+ (V1.0) nForce 680i SLI Motherboard: review by big bruin | Babrbarossa | Reviews & Articles from the Web | 0 | March 22, 2007 09:03 AM |
| Big Bruin reviews 2GB OCZ DDR2 PC2-8500 Platinum SLI-Ready Edition dual channel kit | Supergrover | Reviews & Articles from the Web | 0 | January 2, 2007 03:18 PM |
