Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old June 8, 2007, 10:24 PM
Babrbarossa's Avatar
Super Moderator
Default So the Thermaltake Big Typhoon VX, eh?
the amount of recent buzz surrounding this cooler has been quite surprising. Anandtech decides to take a colser look to see if it's truly deserving. In short, no. They conclude that the tower style coolers are still king- and personally, I would worry about the weight of a cooler like this torquing down on your board. I'm not saying that Anadtech id the be-all and end-all, but they're probably close
More from Anandtech
Gaming Rig: evga 680i rev. A1 // Q6600 @ 3.51 // evga 260GTX 216SC// 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old June 9, 2007, 10:44 AM
Level up: 77% Level up: 77% Level up: 77%
Level: 22 - 313 points to level up
thank god.. I absolutely detest and HATE that cooler.
Old June 9, 2007, 12:48 PM
the new model is a lot better than the old one that uses a backing plate (although i omit it on mine sometimes).
I have a bunch of the older ones and they work great for oc'ing as long as you take the anaemic tt fan off and put a decent one on, or add another on top of it. Part of the reason they work well for me is that they are on caseless rigs so the extra mobo/NB cooling from them is good.
suprisingly tho, my fav these days is the AF 7 ... i even have a couple of overclocked x3210's running with it although they are the ones that oc well on low V. One is running with an upgraded fan on a 6600 at 3.5.
I do tend to stress my cooling since every rig is oc'ed and folding @100% 724. But the convenience of the intel hsf style mounting on them is very nice especially if you do much cpu swapping.
Old June 9, 2007, 03:55 PM
Level up: 59% Level up: 59% Level up: 59%
Level: 8 - 75 points to level up
lol, i asked you before to elaborate on this comment and you did not. i'll suggest you don't make comments you aren't willing to back up.
as for hating a cpu cooler, maybe you should do something better with all that time on your hands.
as to the original topic, i'm glad anandtech reviewed it because i was on the fence whether to replace mine with a ultra extreme. now i will replace it for sure. my bt will work quite nicely in my new htpc.
ASUS P5Q Deluxe
Intel E6600 @ 3.2GHz w/ 1.5v
2 x 2048MB PC2 8800 GSkill @ 1066MHz (5-5-5-15) w/ 2.1v
Sapphire HD 4870 1GB
SoundBlaster X-Fi Platinum
2 x WD1500ADFD RAID 0
4 x WD5000AAKS RAID 0+1
Tt Armor Aluminum Tower
Enermax Galaxy 1000W DXX
DELL 2405FPW, DELL 1505FPW (sideways)
Thermaltake Phase change! Wankerfx Reviews & Articles from the Web 0 March 6, 2008 03:31 PM
Thermaltake DuOrb VGA Cooler Cptn Vortex Water Cooling 23 December 11, 2007 11:37 AM
Thermaltake V1 cpu cooler cdn_Madrach Reviews & Articles from the Web 3 May 22, 2007 12:16 AM
