June 3, 2007, 09:46 AM
 | Hall Of Fame | | Join Date: Dec 2006 Location: New Brunswick
ASUS Vento 7700 Case review by TechGage Kinda reminds me of the 1980s idea of futuristic- looks like it might be quite useful if you're moving your computer around alot, but there are a few issues: All in all, the Asus Vento 7700 is good case that with some redesigning, could be great. I am a bit hesitant to recommend anyone who isn’t completely in love with the looks of the case because not only is the airflow poor, but the price of $130 (US) is a bit steep as well. I personally dislike aluminum cases greatly because they feel flimsy but in the Vento’s case, all of the molded plastic on the outside add a great amount of rigidness to the case and this is welcome in my book. Taking everything into consideration, the Asus Vento 7700 gets a 7 out of 10.- Pros
- Handles rule!
- Tool less design
- Front door swings upward and over the case
- Front LED lights behind the vents
- Aluminum
- Cons
- Front Door feels flimsy
- $130 is a bit much for what you get
- 80mm fans (there’s a reason most cases no longer use these)
More from TechGage
psst, wanna see my binder?
