Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old May 30, 2007, 07:22 AM
Babrbarossa's Avatar
Default Gigabyte Triton 180: budget case review
To sum it up: Good design, but cheap materials....
Reviews of high-end PC cases are all well and good but not everyone is willing or able to lash out big money. Well, this review is for those of you who'd prefer to spend £50 or less and it's the first of a series looking at budget PC cases.
Overall, the Triton 180 put up a pretty good showing, although thermal performance was hampered by the CPU duct.
That duct looks good on paper and adds to the bullet-points on the features-list but turned out to be a hindrance, rather than a help.
But the Triton does still offer an awful lot for the small sum that it costs - though savings have clearly been made by Gigabyte's choice of materials.
However, while there are other cases in and around the Triton's price that do use more expensive materials, they don't necessarily match it in terms of the quality of overall design.
Our view is that the Gigabyte Triton 180 is a capable chassis. It manages to tick most of the right boxes - including support for
water-cooling systems - and is a good all-rounder at the price. Definitely worth considering if you're trying to save a bit of cash on your next major build or if putting together a system that doesn't require a top-end case.
More from Hexus
$126 CAD at NCIX
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old May 30, 2007, 08:44 PM
The Gigabyte Poseidon is a higher-end model and is cheaper in Canada for some reason (although not in the US) ...
Comment Thread for Gigabyte 3D Aurora Case Review SKYMTL Cases 33 January 7, 2011 08:54 PM
Comment thread for Gigabyte P35-DQ6 review sswilson CPU's and Motherboards 36 March 29, 2008 04:51 PM
Gigabyte Poseidon Case Review Cardboard box with DSL Member Reviews 11 June 3, 2007 09:43 AM
