Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old May 24, 2007, 08:19 AM
Babrbarossa's Avatar
Default Mushkin 4GB XP2-8500 review by techPowerUp!
These guys have little channels in the backs of the heatspreaders that are meant to house tubing for watercooling...they're still to bloody expensive with all the cheap 2GB kits around.
  • This 4 GB kit of Mushkin XP2-8500 will cost around $659, which is a lot of money, but for that price you get a performance memory kit that can run high clocks, good timings and comes in 4 GB capacity.
  • <LI nd="4">4 GB <LI nd="5">High clock speed <LI nd="6">Runs fine at default voltage of 1.8V <LI nd="7">Flexible timings
  • Good performance
  • <LI nd="9">Expensive
  • Works best only on 64-bit OS with 64-bit applications
More from techPowerUp!
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old May 24, 2007, 09:08 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeah, they clock a few mhz over the hp2-6400 but are also double the price. Easy decision IMO.
Old May 25, 2007, 04:05 PM
Deathspawner's Avatar
True that, they are priced ridiculously. One of the reasons is because they have to cherry pick every single one of the kits. Not many chips designed for 2GB modules will be able to do 1066MHz reliably.
tPU! didn't really show how far those modules could be pushed via overclocking though. Unless 560MHz was actually their max, but my kit does 600MHz 100% stable...
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
Mushkin HP2 PC2-6400, or Patrior PC2-8500? Mr. Cipher RAM 20 May 25, 2008 01:03 PM
Comment thread for Mushkin XP2 PC2-8500 Ram Review Wankerfx RAM 7 September 18, 2007 06:44 PM
Mushkin 4GB XP2-8500 review by TechGage Babrbarossa Reviews & Articles from the Web 0 May 9, 2007 08:14 AM
Björn3D reviews 2GB Mushkin XP2-8500 dual kit Supergrover Reviews & Articles from the Web 0 December 29, 2006 03:47 PM
