Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old December 18, 2006, 10:42 PM
Supergrover's Avatar
Default AnandTech pits AMD Socket F Opteron vs. Intel Woodcrest processors
"We first started contacting AMD for a Socket-F platform a few weeks before its release date. Typically, when we receive a platform from AMD, it consists of a couple of CPUs, a main board and some memory. This time around AMD decided to send full platforms from a vendor called Colfax (one of AMD's solutions partners). Note that we used the plural of platform: AMD made a fairly bold move and sent a Woodcrest system as well. Both of the systems were configured identically: same case, power supply, hard drives, DVD-ROM and cooling (minus the CPU fans).
Of course any loyal Intel fan is going to cry foul, but rest assured we checked to see that there was no foul play here. The BIOS settings were configured as identically as possible, the fans were all running inside the case, etc. We've wanted to do this kind of comparison for awhile but lacked the equipment in the lab to create two identical systems. As we alluded to above, the only component that wasn't the same was the processor cooling. Intel's thermal design for most Xeon systems is an air duct that is fed by a hefty 6" fan on one side and vented out the rear of the case (see pictures on the next page). This usually produces a system that sounds like a miniature wind tunnel, at least for the server versions. There are of course a few other differences, but most of those relate to the platform: registered DDR2 vs. FB-DIMMs, different chipsets, and different motherboards were used, but that will always be the case."
More @ Anandtech
R.I.P.
Socket A. I still have it! Il Duce CPU's and Motherboards 10 April 13, 2007 10:20 AM
Intel gives Anandtech a Yiddish lesson: Nehalem and Gesher Babrbarossa Press Releases & Tech News 1 March 29, 2007 09:27 AM
X-Bit Lab: Intel Releases Low-Power Quad-Core Processors. Babrbarossa Press Releases & Tech News 0 March 15, 2007 11:06 AM
GamePC reviews Intel Xeon E5345 and X5355 quad-core processors Supergrover Reviews & Articles from the Web 0 January 5, 2007 06:28 PM
