Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old October 22, 2008, 09:22 AM
TopDogZero's Avatar
Default Hardcore PC's Reactor (oil submersed)
Saw this over at Maximum PC and thought it would be a good read. Neat ideas with lots of cooling potential, more so if they can get a phase change in there. But in the end too proprietary, which might be OK for those that buy high end PC's and don't want to bother with the workings of it. But I like to tinker and oil would just make it messy and the proprietary stuff would just make it hard to upgrade, plus I don't have that kind of money for a PC just look at what I'm running now.
Exclusive: Oil Immersion Cooling Goes Mainstream with Hardcore PC's Reactor | Maximum PC
Old October 22, 2008, 10:01 AM
sswilson's Avatar
We'll have to see how well it actually cools, especially if they manage to integrate a peltier on it. One of the long standing issues with oil cooled rigs is that over time the oil tends to warm up and hold the heat but if the pre-release info they've got is correct it looks like they're trying to do something about that.
A lot will depend on what they mean by "proprietary"... can you swap out a CPU? How about memory????
I can't see an enthusiast going for something they can't change components on, and why would a non-enthusiast spend that kind of money to get to where the highest end available proc/vid would probably get them the same performance.....
Old October 22, 2008, 10:55 AM
S_G's Avatar
S_G S_G is offline
Looks like the CPU and memory are easy to swap, but components like GPUs are another matter.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old October 22, 2008, 12:41 PM
hehehehehe TEC coolers generate moisture which in turn solidifies into water. I think if left for a month or two on my floor, it would look like layer gello with the oil on top, and sparks flying everywhere on the bottom LoL
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
Old October 22, 2008, 03:31 PM
donimo's Avatar
TEC coolers don't "generate moisture" the condense it from the surounding air. So in a water free environment like an oil bath, that problem can't exist.
Still not worth it IMHO, in my experience it isn't heat that usually limits the OC, but the components themselves. I have 2 cpus that never see 40* and I cant even get an average OC out of them, where others are getting 100%...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old October 24, 2008, 07:15 PM
lemonlime's Avatar
Hardware Canucks Reviewer
Very cool system. Interesting to see a company bring this to the mainstream. The proprietary nature of the system concerns me as well. I think a retail phase-change solution like a Vapo LS or a well designed watercooling system would be a better choice for an enthusiast.
Old July 27, 2009, 02:07 AM
m1dget's Avatar
I'm always impressed with those kind of computers :)
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
Old July 27, 2009, 02:36 AM
bissa's Avatar
very cool, but as was stated at the end of the reveiw, bunch of theparts are proprietary so you can swap out broken peices nearly as easily. if they made this case like a regular case then it may get more popularity.
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old July 27, 2009, 04:43 AM
gingerbee's Avatar
been around a long time(oil cooling) and not worth it once all the oil heats up even with a great rad. ( this to me is the enzo Ferrari nice to look at but anyone who knows about cars no thank. p.s enzo,murchilego like to burn ha ha
for those that are into it Reactor
Old July 27, 2009, 10:46 AM
Even people who know anything about cars don't like driving Enzo's that much ;) finnicky pos's lol
anyways back on topic!
