TechGage reviews the Habu Gaming mouse- razer and microsoft got together to produce this good-quality, good-looking, customisable gaming peripheral. The Habu's average retail price hovers around $55, so it's not exactly cheap. After using the mouse though, I am confident in recommending it to anyone who's looking for a new mouse or someone who's looking for something a little different. I've been used to using Logitech G mice for the past few years, so I found the Habu to be a refreshing change. That said, I found the Habu to be an excellent gaming mouse, but I didn't enjoy it as much for desktop work. I deal a lot with Photoshop and have to be precise with a few photos I edit, and I just didn't find this mouse to be the best for that job, so I plan to switch between the Habu and G5 depending on what I need to do. As it stands, this is a great product. It costs a little more than a few other mice on the market (but less on average than Razers own DeathAdder) and offers a lot to the consumer. How many mice allow you to alter your sensitivity on a per axis basis? As for this being a Microsoft Habu, I am not sure just how much part they had in the design process seeing as Razers name is plastered everywhere, but the only fact that matters is that it's a product worthy of receiving a nine out of ten on our scale.
__________________ Gaming Rig: evga 680i rev. A1 // Q6600 @ 3.51 // evga 260GTX 216SC// 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
I see a cord on the pic!
__________________ • - EVGA 680I A1 • - QX6800ES G0 @ 3.95Ghz • - SLI BFG 8800GTX @ 626Mhz \ 2000Mhz • - 4GB G.SKILL F2-6400PHU2-HZ @ 1000Mhz • - Ultra X3 1000 Watt • - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX • - WD RaptorX 150GB \ WD500GB \ WD Caviar 250GB • - MountainMod U2-UFO Black Powder Coat • - Dell UltraSharp 24'' Loop #1 : D-Tek FuZion - 2x MCW30 - Cyclone Res - MCP355 w/ Petra's Top - PA120.3 - Tygon Loop #2 : 2x Ek-FC 8800GTX - Ek 150 Rev.2 - MCP355 w/ Petra's Top - PA120.2 - Tygon |
Yeah- it's corded- I'm going back to a corded mouse here soon- I trying to figure out which one to buy right now.
Which one are you using now? I use a G7 (Cordless) as my primary, which has never dropped out on me once. It uses rechargeable batteries that come with the mouse, so if that's your main concern, it's a good choice. Only downside is that the batteries need to be swapped near everyday, but you can just keep recharging them.
__________________ Techgage.com | Editor in Chief Intel Core 2 Extreme QX9770 @ 3.2GHz, ASUS P5K Premium, OCZ 2x2GB PC2-6400, eVGA 8800GT, OCZ ModXStream 720W, Thermalright Ultra-120 Seagate 500GB 7200.11 & 750GB 7200.10, Samsung 20x DVD-RW, ASUS Xonar D2X, Antec P182, Ultrasone PRO 750, Dell 2408WFP, Gentoo 2008.0 |
I'm using an ageing MX700 that has served me well enough for years- I'm not sure what's doing it now, but the signal seems to be weakening- getting missed stroked on both the keyboard and mouse- the mouse doesn't have enough resolution either. I'll look at the G7- I don't mind the battery swapping- I have a charger right in front of me. Thanks for the recommend!
Someone else I know actually had the same problem with their MX700 recently. I believe the G7 is essentially the same thing, just newer specs. I am sure it would wear down over time as well. As for battery swapping, it's annoying after a while, but it takes only a few seconds to swap really. Still, it's great to be gaming with no loss of signal without a cord getting in the way. One thing I've found also... is the battery will die quicker depending on your mousepad. Seems that my fUnc kills it quick, but I know someone else with a G7 and they use it for at least two full days before they need to swap.
__________________ Techgage.com | Editor in Chief Intel Core 2 Extreme QX9770 @ 3.2GHz, ASUS P5K Premium, OCZ 2x2GB PC2-6400, eVGA 8800GT, OCZ ModXStream 720W, Thermalright Ultra-120 Seagate 500GB 7200.11 & 750GB 7200.10, Samsung 20x DVD-RW, ASUS Xonar D2X, Antec P182, Ultrasone PRO 750, Dell 2408WFP, Gentoo 2008.0 Last edited by Deathspawner; April 24, 2007 at 03:02 PM. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Bought microsoft mouse from planetonline.com | Rupert Borland | Peripherals | 3 | June 11, 2007 11:19 AM |
| Saitek's 3200dpi gaming mouse review by xsreviews | cdn_Madrach | Reviews & Articles from the Web | 0 | April 19, 2007 10:14 AM |
| OCZ Equalizer Lazer Gaming Mouse review by TechGage | Babrbarossa | Reviews & Articles from the Web | 5 | April 10, 2007 03:30 PM |
| techPowerUp! reviews Microsoft Habu laser gaming mouse | Supergrover | Reviews & Articles from the Web | 0 | December 31, 2006 01:15 PM |
