Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Buy/Sell & Trade > Price Check
Old September 26, 2013, 01:24 PM
Default CPU of the Gods: 2500K
I have my cpu here. Thinking about going to Haswell. This 2500k is a dream. It overclocks like nothing without the need for extra voltage. You can even hold back a few! Offset -0.06v at 4.2ghz! Temps less than 70'C at full prime95 load on a Coolit Eco II (H60 oem). 4.5ghz is easy to get although I never kept it there longer than a few moments due to my cooler not being sufficient for 4.5ghz load temps. Under a custom water loop or heavy duty cooler I believe this cpu could probably do 4.8 stable.
Never had any hiccups with this cpu. My system has been rock solid at 4.2ghz for ages now.
What do you guys think this superclocking 2500k is worth?
Old September 26, 2013, 01:32 PM
4.2ghz on a 2500k is really nothing. I had my 2500k with a Coolit TEC setup running at 4.7 without breaking a sweat.
Old September 26, 2013, 01:36 PM
great_big_abyss's Avatar
$140 - $150 plus shipping.
Old October 4, 2013, 05:32 AM
Don't get me wrong I can pull that off as well. I just won't with the cooler I have. Its not a heavy weight cooler and I am using uber quiet fans so I can't move air as quick as that would require.
I've booted with it at 5ghz before but I won't even risk testing that on such a rinky dink cooler.
Also, thanks GBA. That price sounds about right.
little help from the folding gods please gingerbee HardwareCanucks F@H Team 22 July 13, 2012 10:55 AM
360 Case Mod of the Gods, “XBOX Supreme”... Mnpctech Off Topic 4 June 17, 2011 01:17 PM
AND PPD WILL SUFFER , THUNDERED THE FOLDING GODS!! _dangtx_ HardwareCanucks F@H Team 39 February 21, 2010 11:51 AM
All of Gods Creatures, Big or Small Soultribunal Off Topic 9 December 13, 2009 07:44 PM
Question for SKYMTL !!!! (or other PSU gods) Delavan Power Supplies 21 February 6, 2009 04:17 AM
