Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Buy/Sell & Trade > Price Check
Old June 25, 2013, 09:29 AM
Bao Bao is offline
Default Price check on... ideally the entire system
Not sure if I am actually going to sell. But there aren't many reasons for me to have a gaming PC anymore.
NZXT Switch 810 Black
NZXT Hale 90 V1 1000W PSU
NZXT White sleeved cable extensions
BitFenix Recon Fan Controller
Delidded i5-3570K @ 4.8Ghz w/ XSPC Raystorm
EVGA Z75-SLI motherboard
4x 4GB Corsair Vengeance DDR3-1600
240GB Vertex 3 Max IOPS SSD
Asus GTX690 with EK waterblock (bought it and haven't installed it yet)
Auzentech X-FI Theatre HD soundcard
Intel Gigabit Lan Card (can remove, most people are happy with the onboard ethernet).
Cooling:
3x 140 MM BitFenix Spectre Pro Fans
XSPC RX240MM Radiator with 4x 120MM Nexus 1000RPM fans
XSPC AX360MM Radiator with 5x 120MM Gentle Typhoon 1850RPM fans
Laing 655 Pump with XSPC Bay reservoir combo
3/8 compression fittings used
3/8 tubing with
Dragon Ice fluid
Asus VG248QE 120HZ LED monitor for the 2D lightboost goodness
System Price Check Please TyrReich Price Check 4 June 24, 2013 07:50 AM
Price Check - Complete System X79 LegendMask Price Check 4 May 29, 2013 12:07 PM
Price Check - System Starance Price Check 0 June 14, 2012 01:31 PM
Price check on AMD system supaflyx3 Price Check 8 November 9, 2011 02:13 PM
System price check Agafaba Off Topic 10 June 13, 2010 03:42 AM
