Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Buy/Sell & Trade > Price Check
Old April 13, 2013, 08:12 AM
great_big_abyss's Avatar
Default Price Check on 3570K
Want a Price Check on an i5 3570K.
Chip will do 4.7 @ 1.35 Vcore, loaded core temp at 70C on an H80i on LOW setting with push/pull (Corsair SP120's). So there is some overhead if you like to push your chips harder than I do.
Want to upgrade to a 3770K and would like to find out what I can get for this chip before I do.
Chip was bought on January 30, 2013, and I still have the receipt, if it helps the price some.
Old April 13, 2013, 08:15 AM
MARSTG's Avatar
200$ shipped would be a fair price
Old April 13, 2013, 08:17 AM
Your_friendly_gamer's Avatar
75 percent of the value sir. But usually I sell my stuff around 60-70 percent and it sells quick. But not sure. average cost = 230
Taxes = 29.9
Total= 260
Your price should be @75 perecnt = 195, if you add that shipped its good!
Old April 13, 2013, 08:19 AM
Okay. So, about $200 shipped, thanks.
Price Check: Bao Price Check 2 May 17, 2012 05:09 PM
Price check boggtrotter59 Off Topic 0 May 1, 2010 06:03 PM
Price Check - i7 965 EE encorp Off Topic 17 April 29, 2010 07:23 PM
Price Check Please Dr_BenD_over Off Topic 2 April 13, 2010 04:14 PM
Price Check mattlef Off Topic 5 July 31, 2009 03:39 PM
