-   Price Check (http://www.hardwarecanucks.com/forum/price-check/)
-   -   SWAP 2 Sapphire 7950's OC Edition for Gigabyte Windforce 3's 670's (http://www.hardwarecanucks.com/forum/price-check/59257-swap-2-sapphire-7950s-oc-edition-gigabyte-windforce-3s-670s.html)
trayton January 21, 2013 12:38 PM
I have an offer to trade straight up my
2 Sapphire 7950 OC Edition (Dual Fan 950MHz)
for his 2 Gigabyte Windforce 3 670's
I'm not sure which cards are going to be better overall.
I like BF3, COD BO2, CS:GO, Diablo 3 etc...
Thanks in advance for any advice!
OmegaRED January 21, 2013 05:13 PM
I think you're getting the better end of the deal those are cool running cards and overclock quite a bit you're basically getting 680's.
Coach January 21, 2013 06:17 PM
I would do that deal in a heart beat.
sf101 January 21, 2013 06:50 PM
i wouldn't .. unless you want to do 3d with a nvidia capable monitor.
the 7950s can oc better than any 670s doesn't really mater what ones and still have more hp under the table.
and they scale better.
great_big_abyss January 21, 2013 07:33 PM
I would do that deal, yes. You're getting the better end of the deal. I would compare a 7950 to a 660Ti.
The only thing that would deter me is the switch from MSI to Gigabyte. But, seeing as they're 670's, yes, worth it.
dandelioneater January 21, 2013 07:39 PM
I'm not sure that there is that big of a difference in performance between the two. I'd go for whichever cards scale better and are supported in xfire/sli for the games you play.
CroSsFiRe2009 January 21, 2013 07:42 PM
Do the trade. As fast as you can. Heck you can even sell the 3 670s to get 7970s
Edit: Oops, guess I read it wrong, 2*. I need sleep:ph34r:
trayton January 21, 2013 08:34 PM
Oh I only get 2 of them just they are called the "gigabyte windforce 3 670"
Your_friendly_gamer January 21, 2013 08:37 PM
are you sure about this? Is there anything wrong with the 670's??? Not sure, if I know anyone that would want to trade 7950's for 670's.
Masteroderus January 21, 2013 09:07 PM
trade is basically +100 bucks
:punk:
