Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Buy/Sell & Trade > Price Check
Old June 14, 2012, 01:31 PM
Trial Member
Default Price Check - System
I have it listed at £1,300, for the lot (below). Its around 7 months old, with a few parts recently upgraded.
System Specs:
Asus Crosshair V Formula AMD 990FX
AMD Phenom II X6 1100T BE
16GB 2x CMZ8GX3M2A1600C7R
Sapphire ATI 6970 HD 2GB
OCZ Agility 3 Series 120GB SATA III SSD
Bigfoot KILLER 2100 Network Card
Western Digital VelociRaptor 80GB
X-Fi Titanium Sound Card
LG Electronics 10x BD-RW SATA Lightscribe Internal Drive
Corsair 800W Gaming Series GS800 High Performance
Corsair 800D - Obsidian Case
Windows 7 Ultimate
3x ViewSonic VX2239WM 22
Cooling:
Feser One NC UV Cooling Fluid Blue & Red
Lian Li FN04 5.25" 6 Channel Fan Controller Black
EK Supreme HF Easy Mount Universal CPU Waterblock : Full Nickel
EK FC6970 V2 Full Cover Waterblock for AMD ATI 6970 Graphics
Card EN Nickel Acetal
XSPC Acrylic Dual 5.25 Dual Loop Reservoir with Two Laing DDC Ultra 18w Pumps
2x Pulse Modding 99.9% Silver Kill Coil
Hardware Labs Black Ice® GT Xtreme Lite 240mm Dual Radiator
Hardware Labs Black Ice® GT Stealth 360mm Triple X Flow Radiator Black
PrimoFlex Pro LRT 3/8" ID - 5/8" OD (10-16mm) Tubing UV Red & Blue
4xAlphacool 1/4" Thread Compression Fitting for 3/8" ID - 5/8" OD Tubing Deep Black
2xRotary Compression Fitting for 3/8" ID - 5/8" OD (10-16mm) Tubing Matt Black
4xLamptron Elite Aluminium Tubing Clamp for 5/8" (16mm) OD Tubing Black
6xBitspower 1/4" Thread Barb Fitting for 3/8" ID Tubing Matt Black
5x Scythe Kaze Jyuni Slip Stream 120mm Fan 1900 RPM
3x AeroCool Shark 140 x 140 x 25mm Case Fan with 7v Resistor Cable
Complete system price check martin_metal_88 Price Check 3 February 6, 2012 05:38 PM
Price check on AMD system supaflyx3 Price Check 8 November 9, 2011 01:13 PM
System price check Agafaba Off Topic 10 June 13, 2010 03:42 AM
Price Check on a complete system norfolk Off Topic 4 February 12, 2010 02:30 AM
Price Check on a complete system norfolk Off Topic 6 February 2, 2010 09:15 AM
