-   Price Check (http://www.hardwarecanucks.com/forum/price-check/)
-   -   Pricecheck: HP Envy 14 (http://www.hardwarecanucks.com/forum/price-check/54098-pricecheck-hp-envy-14-a.html)
coriolis May 9, 2012 06:28 AM
A working laptop, there are scuffs and wear/tear from usage at some parts of the casing. But there is no cracks, nicks or deep scratches. The screen is fine, some marks from the keyboard when you close the screen, but nothing obvious (you can only see it when the screen is off and you are reflecting light off of it). Warranty is done, but everything functions. Battery has been used frequently, but still retains a 2-3 hour charge.
Spec sheet from HP:
14.5" LED-backlit HD+ 1600x900 Display
Windows 7 Home Premium 64-bit
Intel Core i5 450M processor (2.40GHz, 3MB cache)
ATI Mobility Radeon HD 5650 with 1GB VRAM and Intel GMA HD Switchable Graphics
6GB DDR3 RAM
500GB 7200RPM hard drive (Seagate)
Intel Wireless Wi-Fi 6200AGN
Built-in Bluetooth v2.1+EDR
8X slot-loading DVD burner
8-cell Li-ion battery
b1lk1 May 9, 2012 01:59 PM
I'd say somewhere around $400 is more than reasonable, replace the battery and add another $50-75.
