Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > Buy/Sell & Trade > Price Check
Old January 14, 2012, 07:39 AM
lkramer's Avatar
Default Price Check on Parts and System
Parts
I have a Megahalems Rev. B with 2 sets of 120x25mm fan clips, mounting hardware for 1155/1156 socket only, and installation instructions. In addition, the Megahalems will come with a 120mm San Ace PWM fan (9G1212P4G03) and a 4g tube of Arctic Cooling MX-2.
I have 4GB (2x2GB) Crucial DDR3 1333MHz RAM.
System
The specs for the system are:
  • CPU: AMD Phenom II X4 955 BE (C3 stepping)
  • Cooling: Coolit Eco C240
  • Motherboard: ASUS Sabertooth 990FX
  • RAM: 4GB (2x2GB) Kingston HyperX Genesis DDR3-2133MHz CL9 (KHX2133C9AD3X2K2/4GX)
  • Power Supply: Seasonic M12D 850W
  • Hard Drive: WD Blue 640GB (WD6400AAKS-00H2B)
  • Optical Drive: LG DVD Burner
  • Case: Cooler Master CM 690 II Advanced
  • Video Card: XFX Radeon HD 6950 1GB
I have modified the case and optical drive so the LEDs are white. I replaced the case fans (front intake, mid-case, and rear exhaust) with 1450rpm GentleTyphoons. The two fans for the radiator are 3000rpm GentleTyphoons which are modified for PWM control.
The system will come with all of the original case, cooler and motherboard accessories, and documentation.
Thank you.
Old January 14, 2012, 04:11 PM
Chip brand new is $110 or so.
eco 240 I think was $150?
990FX board is $200
Ram now can be had for $45-60 the faster as u have linked maybe $100
Power supply I believe for that one was $165?
HDD $75
optical $22
case $110
6950 1gb brand new around $230
extra parts and work $120?
to be fair becuase it is not brand new, I would say $800-$1k. Yes I know the prices for brand new can be pricey, but, it is not brand new anymore :P
So list out what you paid for said parts, and depending I would knock 10-20% off each then total it.
Brandnew parts listed would be around $1500 or so? so a bit under 1k is still fair and you are not losing much.
Old January 14, 2012, 07:07 PM
Bond007's Avatar
Didn't have too much time to look into it, but I would put the system around the $750 mark. Used computer parts usually go for 70%ish of their current online prices.
Price check pc parts 1366 kazenagi Price Check 4 December 11, 2011 04:09 PM
Price Check old parts Aimbayya Price Check 4 November 30, 2011 11:45 AM
Price check on AMD system supaflyx3 Price Check 8 November 9, 2011 02:13 PM
Price check for a complete system Your_friendly_gamer Price Check 2 October 23, 2011 07:37 PM
System price check Agafaba Off Topic 10 June 13, 2010 03:42 AM
