-   Price Check (http://www.hardwarecanucks.com/forum/price-check/)
-   -   What is my rig worth (http://www.hardwarecanucks.com/forum/price-check/49533-what-my-rig-worth.html)
Adzsask December 18, 2011 09:43 AM
As the title states, what is my rig worth? I would like 3 quotes if possible, a whole rig, whole rig - case, and parted. Having some financial problems (off work for 8 weeks, then fired while on sick leave) Everything under my specs, as well as a few spare parts I have , PCP&C 1KW PSU, H-50 with a 3 blade 3300RPM delta server fan, 3 GT AP-15's, few misc. 120mm fan's , 220mm? the big fan from a haf 932 case brand new with the metal guard, couple sound cards (I am guessing 7-10 years old) also a corsair 800D, missing one of the bay covers(i'll toss in an IDE burner to fill the hole if needed) also modded the side panel window, it is now made from lexan not plexi and has holes cut for 120mm fans aimed directly where my old crossfired 5870's used to live.
Thank everyone who looked and contributed to this thread.
Adzsask December 19, 2011 07:14 AM
Is something wrong?, 80 views and not one response.
Soullessone21 December 19, 2011 07:28 AM
how about some specs in the price check section :P
KaptCrunch December 19, 2011 07:38 AM
from Spec's button of poster
Motherboard: Gigabyte GA X58a-UD7 rev 1.0
Processor: i7 950 @ 4301 MHz
Memory: 6X2GB Corsair XMS3 1600 MHz
Video: SLI GTX 460 @ 900 core
HDD: 320GB seagate 1TB WD green
PSU: Corsair GS800
Case: Thermaltake Xaser 3
Optical: 2X ASUS CD/DVD burner
Monitor: 22in hannspree LCD
OS: win 7 64
Adzsask December 19, 2011 07:55 AM
Ya... you didn't even read the post did you.
yycraven December 19, 2011 08:18 AM
There is one fellow SK I saw his system for $600 or so, you selling the LCD as well if so add another 100 or so.
Adzsask December 19, 2011 08:41 AM
For $700 I'll keep it, and yes every component, monitor does me no good without a PC.
SugarJ December 19, 2011 08:57 AM
It's always easier if you provide more information rather than attitude. I looked at your thread when you first posted it and couldn't be bothered to look up your specs.
As for your system, 600-650 is about all it's worth, unfortunately. The CPU/Mobo/Ram combo is probably worth about $350. The GPU's about $100 each.
Soullessone21 December 19, 2011 09:21 AM
Thank you Sugar and I would agree with your pricing but more like 500-600 as they are aging hardware but still not a bad system at all
Adzsask December 19, 2011 09:24 AM
Sorry, but you would be a bit short tempered to if you were battling ulcers, and have no income because you were fired while on sick leave. Thank all of you who read the OP, and gave me some numbers, I will be keeping this stuff, not worth it to sell at those prices.(payed almost $400 for mobo alone)
