-   Price Check (http://www.hardwarecanucks.com/forum/price-check/)
-   -   My full WC system (http://www.hardwarecanucks.com/forum/price-check/45865-my-full-wc-system.html)
Bojamijams August 23, 2011 02:10 PM
My full WC system
Silverstone TJ07-BW (Replaced 2x top 120mm with S-FLEX F and 2x back 92mm with S-FLEX F)
Silverstone CFP51 5.25" to 3.5" Bay w/ Fan (SilverStone Technology Co., Ltd.)
Scythe Kaze Master 4 channel Fan controller for Radiator fans+Top 120mm fans+front CFP51 FAN
2x UV CCFL Tubes + UV Red Tubing
HWLabs 480GTX Radiator x4 Scythe S-FLEX F Fans
D5 Pump w/ EK Top
FrozenQ Fuzion Reservoir Rev6 (UV RED)
Fuzion V2 CPU Block
Koolance 5850FC Block
Bitspower 1/2ID 3/4OD compressions fittings on all connections
2x Koolance VL4N QDC in front of CPU Block and after GPU Block
evga Classified X58 E760
i7 920D0
6gb OCZ Ram
XFX 5850 Video Card
Asus Xonar DG sound card
WD 640gb AAKS Hard Drive
Corsair HX850
The system clocks can be seen in my sig.
Thanks for your input
zsamz_ August 23, 2011 05:13 PM
you gonna better off parting it out:whistle:
1100-1300
Bojamijams August 23, 2011 07:53 PM
I have a friend whose interested in the whole thing so he can just plug and play, but I really have no idea what something like this would be worth so.. take a shot :)
supaflyx3 August 23, 2011 07:59 PM
probably $750-900, but I'm no expert on WC gear.
lowfat August 23, 2011 08:04 PM
I'd say $1350 - $1500.
SugarJ August 23, 2011 09:10 PM
Ya, the case alone is over $300 new. My best guess for a system price would fall in lowfat's range, around $1400.
_dangtx_ August 23, 2011 09:24 PM
try for a grand,see what he says. tell him how much you paid new and they are already installed,leak tested etc
Bojamijams August 24, 2011 05:03 AM
Thank you guys
JMCD August 24, 2011 05:12 AM
i'd say 1350 at the lowest.
Bojamijams August 24, 2011 05:24 AM
He's a great friend so he deserves a great friend discount. $1000 it will be.
