| Quote:
__________________ I am blinded by the light, but in darkness I cannot see. Only in the shadow does everything become clear. Specs: Windows Vista Ultimate 64-bit SP1 (Dell OEM disc) (2x) Corsair Twin2X 2048-6400 (4 GB total) (757.5 MHz, 4-4-4-12) Intel Core2Duo E6600 2.4 GHz (running at 3.408 GHz)(9 multiplier x 378.75 FSB) @ 1.53125 volts Asus P5N32-E SLI (nForce 680i chipset) eGeForce 8800 GTS 320 MB Superclocked Watercooling |
Here is the link NCIX.com - Buy Arctic Cooling Accelero Twin Turbo VGA Cooler - ACCELERO-TWINTURBO In Canada. Im going to contact them to see if I can get an availibility quote |
When I finally get my damned expenses paid from work, lol, I plan on getting a couple 4850's and two of these coolers to go along with them, the only think is that I'm anxiously awaiting a review that speaks on the Ambient, or Crossfire friendlyness... I'd assume that there would be a decent amount of heat generated in between the two cards specifically because there is no actual "exhaust" like the other (stock) cooling solutions...
__________________ My Rig: E8400 4.0GHZ (3.0ghz) | Asus P5Q-E | Xigmatek HDT-S1283 HSF | EVGA GTX 280 | 2x Mushkin Ascent PC2-8000 Dual Channel 4Gb 2x 320gb WD HDD 7200rpm - 1x 160gb WD HDD 7200RPM | Coolermaster 650W PSU | Silverstone FT01 CSE | Samsung SyncMaster 216bw ---------------- My Silverstone Fortress Mod --------------- Upcoming Changes/Upgrades: ------------------ Heatware: mattlef Positive: 3 Negative: 0 Neutral: 0 Click Here Click Here For Ebay ------------------- |
I'd like to see those results my temps are pretty similiar with the Akimbo on my 8800GT in sli, however the bottom tends to be about 3 degrees warmer then the top. I have been debating about trying something new and if you yield good results I will probably go with them. EE
__________________ The Blue Box Biostar T-Power I45 / Intel E8400 EO 1.4v @ 4.25Ghz / Sunbeam Core Contact Freezer / Muskin Ascent Redline XP2-8000 2x2Gb / EVGA GTX280 1Gb / Samsung Spinpoint F1 750Gb 32Mb x 2 / Razer Barracuda AC-1 Gaming Audio / Antec P182 / Antec TPQ 850 Watt / Windows XP MCE SP3 |
Using one of these on my HD4850. One thing I'm not sure of is if I got the power connected right to this thing. I've got the connector going to the video card's original fan connector, and then the y cable type connector going from there into a standard molex. The fans are supposed to be PWM, so I figure it uses the card's fan connector to get temperature information, while the molex connector powers it, but I'm not sure, would appreciate if someone can confirm this. It cools fairly well, but it's a loud sucker at full speed, so right now I've kept it at 65% or so since the auto fan control on the HD4800's doesn't exist. At this speed which I would say is pretty silent, it keeps my card idling under 40 celsius and load seems to top out at about 57 celsius; tested using furmark. Pretty good cooling, but the noise level isn't what I was expecting. |
| Quote:
| Thread Tools | |
| Display Modes | |
