Lian-Li has just launched the very impressive Tyr PC-X2000 HTPC/Gaming Full Tower Case:
"24 June 2008, Taipei, Taiwan – Lian-Li Industrial Co. Ltd has launched the Tyr X2000 chassis designed originally to resemble a speaker, but later re-aligned to become the most unique HTPC/Gaming Chassis on the market today. With a sleek tall look aspiring to Tyr, the original Norse God of single combat and heroic glory, the slender beveled front panel signifies the armored helm of Tyr. The side panels accept 2x 5.25” Optical Device Drives and one 3.5” drive, which are inserted from either the left or right side, while the front face is for ergonomics and airflow, filtered by a removable nylon filter.
Lian Li is well known for craftsmanship and quality, and the Tyr X2000 is no exception. Embracing the new style, with an all black anodized interior, an easily removable front panel which hides 3x 140mm silent intake fans, protected by the removable and washable nylon dust cover. The top mounted multimedia ports include 4x USB 2.0 ports, 1x Firewire (IEEE1394), 1x E-SATA, and HD AC97 Audio ports. The patented tool-less latch allows easy access to the compartmented heat zones inside with a special VGA support bar to give added rigidity to extra long VGA cards. Other traditional Lian Li innovations have been improved upon such as the removable motherboard tray with holes for better CPU cooling and added anti-vibration couplings, as well as the specially filed and brushed finish to reduce sharp edges giving the case both style, and an aspect of safety.
More features include support for Extended ATX, ATX, and Micro-ATX motherboards, 8x PCI slots, water cooling support, 1x 140mm silent exhaust fan for the motherboard heat zone, 2x 80mm exhaust fans for the HDD bay heat zone and further support for 2x PSU’s (220mm long supported) with anti-vibration and insulated rubber strips on the mounting platforms. Specialized HDD mounting racks (supports 6x HDDs) with special handles which are attached to protect your HDD’s, while keeping them vibration free in their bay. The SATA back panel is a hot swap device which can support RAID 0 & 1.The case was designed with silence in mind, so specialized sound insulation material combines with the 2mm thick aluminum alloy side panels to keep your system whisper quiet. Taking things to the extreme in comfort and convenience, Lian Li mounts the case on rubber pads to minimize any vibrations that could add to noise. Additional touches include vented PCI brackets which add to through flow of air and prevent heat buildup."
Product Page.
