| Intel demonstrated ET: Quake Wars running in basic HD (720p) resolution, which is, according to our knowledge, the first time the company was able to render the game using a standard video resolution, instead of 1024 x 1024 or 512 x 512 pixels. Seeing ETQW running in 14-29 frames per second in 1280x720 has brought up our hopes for Intel's CPU architecture, since we do not believe that CPUs would deliver a similar performance when rasterizing graphics. For the record, the demonstration ran on a 16-core (4 socket, 4 core) Tigerton system running at 2.93 GHz. TG Daily - Intel converts ET: Quake Wars to ray-tracing Very gorgeous graphics. Stuff that we currently only could only see pre-rendered. It's still a long way to go to increase the FPS to a more playable rate, and launched those 16 cores CPUs. By then, shouldn't GPU makers be able to reach the same level? |
Maybe I'm missing something, but this doesn't seem that impressive. 4 sockets, 4 cores w/ hyperthreads meaning 32 threads at once ... All at the low-low cost of 2 arms and a leg ... able to run ET:QW w/ ray-tracing @ 1280x720 w/ barely-playable framerates ... |
Isn't the "big deal" the fact that it's doing all of that "real time" from scratch rather than using an engine?
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| Quote:
![]() They won't give up on this ray tracing will they. "Hey guys look! I can make the same grphics t a lower res and framerate with only a super computer! Feasible, no?"
__________________ Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic My Heatware! | Got RMA? Tell us your experience! | VOIP Help? PM ME! |
It's a big deal because so far Ray Tracing only exist for pre-rendered cutscenes, movies, or images. It's almost impossible to render in real time, because it takes a lot of computational power (takes so long to render). Games usually use the Rasterization technique instead. One really distinct difference when using Ray Tracing is, reflections look a lot nicer (on water or other reflective surfaces). It's another step towards realism. Take the reflections on this image for example, or this Quake Wars screenshot. You can see the whole world reflections on each of those mirror/water droplets. So far many people have voiced that Ray Tracing is currently (and in the near future) impossible to do for gaming, but Intel claimed that they're able to. Sorry, it's kinda too technical :P EDIT: To add another point, if Intel is able to pull this off (in the near future). They can start claiming that with their 16-core CPU, you no longer need an additional video card to play games (provided that future games are going to use the ray-tracing technique). |
| Quote:
This is the exact same thing as AMD's Cinema 2.0 technology demo. Rendering in real-time, eventually shooting for photo-realistic rendering on the fly. It's a step forward, don't be fooled by the low performance. Rendering speed has finally approached an actual smooth framerate, its an impressive feat.
__________________ Mobo: DFI 790X-M2R Proc: AMD PHENOM X4 9850 Ram: OCZ Platinum 2X 2GB @ 1066 VIDEO: 3 x Visiontek HD3870 @ 900/1300, hard-modded |
I don't think this is far away at all, given that intel's upcoming nehalem CPU is capable of 8 cores with hyperthreading. I'm guessing one or 2 CPU generations after that (2-5 years) will mean that CPUs can do decent onboard video. A few generations after that will mean they can compete with GPUs. I'm sure we'll see it within the next 10 years.
__________________ Core 2 Quad 6600 @ 2.8 GHz 2 x 2GB G.Skill PC2-8500 @ DDR2-1040 MHz EVGA GeForce 9600GT SC Gigabyte GA-P35-DS3L Antec Truepower Trio 650W Scythe Ninja Rev B w/ MX-2 CM690 w/ 1-80mm, 6-120mm fans. |
| Thread Tools | |
| Display Modes | |
