Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old June 15, 2008, 11:11 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Default MSI Introduces Intel P43 & P45 Motherboard Lineup
MSI has finally revealed their Intel P43 Express and P45 Express motherboards, which comprises eight models in total!
"MSI recently launched the MSI P45 mainboard series based on the new Intel P45 chipset. MSI offers a complete range from the mid-range segment to the high-end solutions. The MSI P45 series mainboards are equipped with server-class DrMOS which provides high power efficiency, more stable overclocking and lower temperatures. All the MSI motherboards have a zero noise solution with the MSI Circu-Pipe, Heatpipe or Heatsink."
MSI P45 Diamond
  • Supports Intel Core™ 2 Extreme/Quad/Duo & 45nm Penryn CPU’s, FSB up to 2008MHz OC
  • Supports DDR3-2008 memory
  • Equipped with DrMOS
  • Creative X-Fi Xtreme Audio independent sound card
  • Circu-Pipe Liquid water cooling and Heat-Pipe thermal design
  • Dual PCI Express 2.0 x16 support ATI CrossFireX (dual X8)
  • TPM pinheader
MSI P45D3 Platinum
  • Circu-Pipe 2 heat-pipe thermal design
  • TPM pinheader
MSI P45 Platinum
  • Support DDR2-1200 memory
  • TPM pinheader
MSI P45 Neo2-FR
  • 8 (7.1) Channel HD audio
  • Heat-Pipe thermal design
  • TPM pinheader
Click here to check out the other four models.
