Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old May 21, 2008, 11:57 AM
Default Qimonda Bringing GDDR5 to ATI's Radeon 4000-series
AMD has decided to lead the pack where GPU memory is concerned, and Qimonda is the company to deliver. The Radeon 4000 series, which will launch next month, will be the first to feature GDDR5, an evolutionary upgrade to GDDR4, which will feature faster speeds, improved bandwidth and more efficient power features.
Launch GDDR5 parts will be offered in speeds from 900MHz (3.6Gb/s) up to 1GHz (4.0Gb/s) and will run on 1.5v, compared to the 1.8v for GDDR4. Launch cards will not use memory speeds beyond 4.0Gb/s on the 16M x 32 arrangement, however, as the faster and higher-density chips will not be available to Q3 and Q4 (which go up to 5Gb/s).
Both the speed increases and feature-additions are what makes any new DRAM type worthwhile, and GDDR5 does have a few tricks up its sleeves. New is an error detection mechanism, which is similar to ECC server memory. It calculates an eight-bit CRC algorithm on each data burst and instantly allows a calculation repeat on a detected error, improving efficiency.
Then we have clamshell mode, which enables a 32 I/O to be reduced to 16 I/O, allowing each DQ to connect to a separate IC in x16 mode. This feature is a little confusing, as it makes no difference in bandwidth, so the question is, what's the purpose? I'll be checking with Qimonda to see if they have an answer up their sleeves.
Munich, May 21, 2008 - Qimonda AG, a leading manufacturer of memory products, today announced that the company has won AMD as launch partner for the new graphics standard GDDR5. Qimonda already started mass production and the volume shipping of GDDR5 512Mbit components with a speed of 4.0Gbps to AMD, a leading global provider of innovative processing solutions in the computing, graphics and consumer electronics markets.
Source: Qimonda
</img> </img>
More...
Old May 26, 2008, 08:44 PM
darksideleader's Avatar
not bad, looking forward to the Hd 4x series.
Runnin' Stock, Cool and Fast
Q6700
Thermaltake Big Typhoon w/ Scythe Kama PWN Fan
MSI P6N SLI Platinum
OCZ Vista Performance Platinum 4x2GB
2x Western Digital Caviar Blue 500GB RAID 0
BFG & ASUS GTS 250 SLI 1GB
Acer AL2216W 22" LCD Monitor + 17" Samsung Sync Master 750
Antec TruePower Trio 650 Watt
NZXT Gamma
Windows 7 Home Premium (64-bit)
