Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old May 15, 2008, 01:16 PM
Default Thermaltake Introduces the ProWater 850i
The internal DIY liquid cooling system has always been the top choice of gamers worldwide. To fulfill the heavy demands of these players, Thermaltake is launching a brand new series of DIY liquid cooling systems, the ProWater Series, and the first model to be introduced is the new “PW850i” that incorporates the latest production techniques and technology of the internal liquid cooling segment.
The P500 Pump used in the PW850i has a maximum high output of 500L per hour to support the liquid cooling system even under heavy load; the hard-wearing ceramic bearing further increases the life span of the pump, users will not need to worry about pump failure even with extended VGA or memory liquid cooling components. The professionally designed inlet and outlet will eliminate the possibility of air blockages. The PW850i also adopts an automotive style radiator with Thermaltake exclusive "Dimple Dimpled Tubes" DDT technology rather than traditional round tubes, and with the adjustable 120mm fan (1300~2400 RPM); CPU heat will be transmitted efficiently in the coordinated system environment.
