-   Press Releases & Tech News (http://www.hardwarecanucks.com/forum/press-releases-tech-news/)
-   -   EK Water Blocks Announces De-Lidded Ivy Bridge CPU Cooling Solutions [techpowerup] (http://www.hardwarecanucks.com/forum/press-releases-tech-news/60440-ek-water-blocks-announces-de-lidded-ivy-bridge-cpu-cooling-solutions-techpowerup.html)
G777 March 28, 2013 10:43 AM
EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is proud to introduce the EK-Supremacy PreciseMount Add-on Naked Ivy.
Source
Pretty kool
lowfat March 28, 2013 11:16 AM
I'd grab one in a second if they had them available for their older blocks.
Bao March 28, 2013 01:15 PM
This is neat, hopefullly XSPC releases their own version of this.
sswilson March 28, 2013 02:33 PM
Cool!!! So this is specifically for running without the "lid"? I thought folks weren't actually running naked, I was under the impression that they were still putting the lid back in place only without the factory goop that wasn't providing a good thermal transfer.
lowfat March 28, 2013 02:49 PM
They do. But some people would run naked if they could. The problem is that stock mounting just won't work. You'd run a high risk of crushing the die if your guess work of tightening the block. At least prevents me from doing it.
What EK should do is also sell a shim for the die.
mkultra March 31, 2013 07:56 AM
yep there should be some kind of gasket surrounding the die.
I am very proud of EK or releasing such a product, it takes huge balls
Perineum March 31, 2013 09:37 AM
It seems you have to remove the socket clamp? That doesn't really make sense, I'm sure a water block could be built to take up the space that the IHS did....
Bond007 March 31, 2013 10:41 AM
Not sure what their reasoning is for the way they made it, but good on them for making such a low volume enthusiast part.
