Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old April 22, 2008, 01:31 PM
Default More 55nm GeForce 9800 GT Info
Earlier, we revealed that Nvidia is planning to release GeForce 9800 GT based on 55nm G92 core in July and now we learned a little more details on this new card. The new 9800GT card is codenamed G92-280 and it is using a new P393-C00 PCB that supports Hybrid Power. There will be 256MB and 512MB GDDR3 versions that clocked at 900MHz and 975MHz respectively. The core clock has not been determined yet but it should clock higher than the current GeForce 8800 GT which is at 600MHz default. Outputs are 2 x DVI-I and HDTV.
Old April 22, 2008, 03:20 PM
I thought the G92 was 65nm. Does this mean a die and process shrink for the 9800?
Old April 24, 2008, 11:25 AM
darksideleader's Avatar
doubt it, they'll probably just release something new on the 55nm proccess.
