Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old April 17, 2008, 06:42 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by magictorch View Post
Is this some kind of special pair of chips supplied by Intel to generate buzz around the release of skulltrail?...Seems like every-time a new chip comes out these monster ocs on them are reported using fairly standard methods which dont seem to be replicated by the masses---- either way very impressive.
You hit the nail on the head to a certain extent. Hand-picked motherboards, processors, memory, GPUs and whatnot accompanied with a tweaked install of Windows. It is all done to generate buzz and it does a hell of a good job of it at that. It is all about PR and good marketing and if I was in the position of Intel, Nvidia or any other company I would do the same thing.
Old April 17, 2008, 06:59 PM
magictorch's Avatar
Originally Posted by Mr. Cipher View Post
I don't think 1.9v and using 300L of LN2 to cool a system is standard for the masses! I wish I had access to that much coolant.
yea I meant the reports in one of the links of 4.5ghz with a simple water system while others were getting close to that on air the 6ghz oc was huge but still doubt all the chips will do that
Old April 17, 2008, 10:01 PM
1Tanker's Avatar
It's not really any different than any other "sport/pastime" advertising for the sponsor. NASCAR(not a fan) and most other races create sales. It's just the way the human brain works... "monkey see, monkey thinks he can do".
Old April 18, 2008, 07:41 AM
Eldonko's Avatar
Hardware Canucks Reviewer
You do, head to your local Air Liquide and they will sell you as much as you want. :D Bring a dewar and alot of $ though heheh.
