Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old March 9, 2012, 02:53 PM
BrainEater's Avatar
Default L.E.D. physics.
Hey look at this :
LED's Efficiency Exceeds 100% - Slashdot
Please disregard all the "hype".....it's not really more than 100% efficient.Here's what I gleaned from it ;
It appears certain LED setups operating in the 'inefficient zones' of the voltage-light graph actually emit photons greater than the electrical input.....and they seem to act as 'peltier-coolers' in doing so.
Seems interesting.I suspect this is an important discovery.I'll be looking into this more.
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old March 9, 2012, 03:04 PM
dandelioneater's Avatar
Makes one wonder....
Old March 9, 2012, 03:09 PM
BrainEater's Avatar
Sure it's possible.
Seems like thats almost a Light-Emitting-Peltier.
Nice pic tho !!
Old March 9, 2012, 03:19 PM
If these LED's do what the article says, it kind of destroys all conventional physics and scientific theory to date. Energy in doesn't necessarily equal energy out any more.
Old March 9, 2012, 03:37 PM
Well that's not entirely true, when they say it works as a cooler it is because you are putting electricity in and the diode is absorbing heat from around it. Overall the input = the ouput you are just getting input from more than one source. These lights would be less efficient electrically under cold conditions and would probably be quite a bit dimmer. Lets just say they won't be used as heat lamps or in your tv without a space heater.
Old March 9, 2012, 03:43 PM
makes sense now.
Old March 10, 2012, 10:51 AM
BrainEater's Avatar
It's wordy , but the abstract for the research paper explains it perfectly :
A heated semiconductor light-emitting diode at low forward bias voltage V<kBT/q is shown to use electrical work to pump heat from the lattice to the photon field. Here the rates of both radiative and nonradiative recombination have contributions at linear order in V. As a result the device’s wall-plug (i.e., power conversion) efficiency is inversely proportional to its output power and diverges as V approaches zero. Experiments directly confirm for the first time that this behavior continues beyond the conventional limit of unity electrical-to-optical power conversion efficiency.
I'm curious about just how much heat it can move.
I almost wanna spend the 5$ to read the paper.
Best Physics Card? Beastylemon Video Cards 1 September 5, 2011 04:23 PM
3 way sli or Sli and physics? frosty Video Cards 13 July 18, 2010 11:49 AM
PHYSICS metalcore Video Cards 6 January 18, 2009 12:49 PM
One Big Step for Physics? MpG Press Releases & Tech News 18 April 15, 2008 06:51 PM
AMD says GPU physics is dead until DirectX 11 Shadowmeph Press Releases & Tech News 12 November 26, 2007 06:53 PM
