Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old February 21, 2012, 12:06 PM
News Editor
Default Spire Introduces the TME III CPU Cooler
The TMEIII is the next evolution of the hugely successful TherMax Eclipse CPU cooler series. The increased number of heat-pipes combined with a higher number and density of dimpled fins and crowned with two (2) high airflow, Nano Bearing DC fans for extreme cooling performance. Five (5) U-shaped 8 mm all-copper heat-pipes are in direct contact with the CPU heat-spreader (heat source), rapid heat transfer to the 45 aluminum dimpled fins providing a larger surface area for optimum heat dissipation.
Read more here: Spire Introduces the TME III CPU Cooler | Hardware Canucks
Follow me on Twitter: @thesamreynolds
Follow Hardware Canucks on Twitter:
@hardwarecanucks
Old February 21, 2012, 01:45 PM
sswilson's Avatar
- Five (5) 8 mm all copper U-shaped sinter-powder heat-pipes
- Heat-pipe base direct contact with all of the processor area
- Straight lined heat-pipes allowing air to easily pass through
- Stamped aluminum wide fins for best surface rate
- Dimpled surface fin for increased heat transfer rate
- All black-Nickel coated heat-pipes to preserve killer looks from oxidation
- Two (2pcs) 120 mm BlackStar 7 blade DC fan included
- High Quality, Long MTBF precision Nano – Bearing
- Supports AM2/AM3 socket 939/940/ 775/1155/1156 & 1366/2011
- Best cooling performance on hot CPUs up to TDP 150 W
- PWM fan speed control, 4 Pin Mainboard Connector
So..... do we buy this? I can accept that it might provide more surface area, but wonder if the disruption of airflow on the bottom from the dimples would negate any benefit........
Old February 21, 2012, 02:08 PM
Soultribunal's Avatar
It would just create more small little eddies and interference but a High static pressure fan should be able to overcome that.
Though I would have to test it to be sure.
-ST
www.realhardwarereviews.com
Old February 23, 2012, 09:06 AM
I'm guessing the thought is that it is similar to a golf ball, as long as you can keep air flow laminar (the dimples can't be too big or they destroy the laminar sublayer adjacent to the fins) it would increase cooling capacity.
I agree it would have to be tested, but fan static pressure shouldn't matter too much because laminar sublayer is based off of viscosity rather than air speed or pressure.
Suggestion : Review on the Spire Thermax Eclipse II CPU Cooler O.CModderz Suggestions & Feedback 0 November 23, 2011 02:46 AM
Spire Introduces the Swirl Cylinder Towering CPU Cooler Sam_Reynolds Press Releases & Tech News 13 June 4, 2011 11:42 AM
Slimod 282 Direct-Touch VGA cooler from Spire FiXT Press Releases & Tech News 3 August 11, 2010 06:28 PM
Cooler Master Introduces New Low Profile Cooler - Vortex Plus FiXT Press Releases & Tech News 0 April 20, 2010 11:27 AM
Spire Launches SilverBlaze VGA Cooler MAC Press Releases & Tech News 2 August 2, 2008 11:58 AM
