Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old March 5, 2008, 06:13 AM
CMetaphor's Avatar
Quadfather
I still say I wanna know the performance numbers of the built-in gpu in combination with a high end graphics card, even just one. Would It actually improve the 3dmark scores of even a 3870? I wonder....
Old March 5, 2008, 06:43 AM
Cheator's Avatar
Yeah it would improve it but not by much. There are a few reviews out there that show that the difference is minimal but worth it for the price it comes for ($80 for a mobo)
My Heatware![/SIZE][/FONT] | Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old March 5, 2008, 07:58 AM
CMetaphor's Avatar
Quadfather
But.... But... I want it to do the physics processing for a Crossfire setup
Old March 5, 2008, 11:36 AM
Cheator's Avatar
That might not happen for a while. ATI says that MS doesn't have it on it's plate for DX.
Old March 5, 2008, 12:03 PM
From what I've been reading it doesn't sound like Hybrid Crossfire will be supported with high end graphics cards, and if it was supported or gets support for high end cards in the future I don't think it will make much of an improvement over a single 3870. The whole board is only worth a $100 and I'm guessing the onboard GPU is maybe worth $20 tops. It looks like the Hybrid Crossfire is aimed more at budget PCs with the option to upgrade the GPU power the same way you would add extra ram to a system.
Old March 17, 2008, 07:38 PM
Hybrid Crossfire only works with HD 2400, HD 3400, and HD 3600 series GPUs ... It is disabled by default when using faster cards as it wouldn't make any more than a negligible difference.
Can you plug a 3870 x2 into a 780g? supernode Video Cards 6 September 13, 2008 01:51 PM
e6600 using p35 chipset? Shadowmeph CPU's and Motherboards 7 January 7, 2008 11:53 AM
Chipset cooler for A8N SLI Cptn Vortex Water Cooling 4 December 10, 2007 02:34 PM
Trying to choose a motherboard/chipset bmfmass CPU's and Motherboards 14 November 21, 2007 04:24 PM
AMD 690 Chipset sswilson Press Releases & Tech News 4 March 2, 2007 12:54 PM
