Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old October 25, 2011, 02:34 PM
martin_metal_88's Avatar
Originally Posted by keto View Post
Socket 2011 is the high end enthusiast + server platform. There are lots of applications that can benefit from 8X8GB = 64GB of RAM, plus the uses mentioned by Eldonko above. The RAM will run in 4 channel (socket 1366 = 3 channel, socket 1155 = 2 channel) with apparently ridiculously good bandwidth.
Well, I could have explain myself better. I don't understand why the UD7 have only 4 slot while the UD5 have 8.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old October 25, 2011, 07:00 PM
Soultribunal's Avatar
Someone goofed when they thought out the design?
No idea on that one MM. It should be the other way around.
ST
Old October 25, 2011, 07:50 PM
Originally Posted by jibz View Post
I just remember my first gigabyte board, a MA770-ud3, and I touched the VRM cooler while it was running and it had to have been ~80c dilivering power to a low end dual core and I wondered what that would do to the lifespan of the board. So I always look for a little more cooling on my mobos.
My MA770-UD3 is still fine after about a month of overclocked folding with a Phenom 9950 and the VRMs hitting over 108 Celsius, plus a few months of folding with the same Phenom 9950 at stock. I'll make a post when it fries
Back on topic, it looks like you'll want a top exhaust on your case to make use of any of these motherboards. The hottest portion (VRM) runs along the top of the board, and a classic front-to-back airflow pattern with tower heat sink will either create a hot spot at the top of the case or heat up the DIMMs between the socket and the I/O plate. Then again, even the UD3 has enough VRM for an overclocked Bulldozer chip, so maybe it actually won't heat up that much with a chip based off Sandy Bridge?
Do these boards still have half their SATA ports broken?
Old October 25, 2011, 08:19 PM
**SPECULATION** running 4 sticks of RAM (4x2G, 4x4G) is going to be adequate for most hardcore overclockers, who this UD7 **generalizing** is marketed towards. High overclocks are usually harder to achieve the more RAM you add to the equation.
I expect the overclocking community is going to have lots of debugging requests/threads for guys with 8 sticks trying to stabilize their overclocks.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old October 26, 2011, 04:40 PM
That could be true Keto, at least I hope our revier will get some info about that ;) hint hint :P
Ask for more
Martin_metal_88
Old October 26, 2011, 05:18 PM
yycraven's Avatar
Do like the boards the way there set up. The UD5 looks very nice thinking of buy one when they come out.
When will HWC have a review on these
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Auzentech Cappuccino EX Sneak Peek Robscix Audio 8 October 11, 2011 09:48 AM
HD6990 SNEAK PEEK Delavan Rumor Mill 39 March 7, 2011 08:54 PM
GIGABYTE Ships All New B3 6 Series Motherboards FiXT Press Releases & Tech News 8 February 28, 2011 08:07 AM
TweakTown's sneak peek at GeCube's dual GPU Gemini 3 Supergrover Press Releases & Tech News 3 September 29, 2007 07:23 PM
PC Mechanic's sneak peek at Firefox 3 Supergrover Press Releases & Tech News 0 August 24, 2007 05:10 PM
